1. Trbek94's Avatar
    Hello,
    Can someone tell me what does crossed i sign in the upper left corner mean (that happend after the offical update I've made through Sam Kies)?
    And one more question, why there is no sound while reciving any kind of notification,though there is the LED sign! (sound is turne ON and voulemd up) see the attachment below !
    Thanks!
    08-13-2012 08:03 AM
  2. cgardnervt's Avatar
    I think I get that when an app fails. Then again I have only seen it a handful of times. So I am still not 100% sure. Have you reset your phone? Does it not go away at all?
    08-13-2012 08:56 AM
  3. johnjaycee's Avatar
    The crossed I is because notifications is turned off in the pull down menu, probably caught it by accident. Just press again to receive notifications
    Trbek94 likes this.
    08-13-2012 10:12 AM
  4. BEARD GANG's Avatar
    Yeh hes right
    08-13-2012 10:37 AM
  5. Trbek94's Avatar
    Thank you very much, I have my s3 for a week and it's my 1st android phone, so i'm kind of a nooby
    08-13-2012 11:03 AM
  6. Mayada Hussein's Avatar
    Perfect, Thanks!
    05-12-2013 06:18 PM
  7. meyerweb#CB's Avatar
    On at least one carrier version of the S3, notifications are turned off when watching videos, to prevent interruption of the video. This symbol appears then, too.
    05-12-2013 10:33 PM
