1. Red Android's Avatar
    Hi I have a garnet red S3 (my first smartphone). I tried getting a candyshell case and apparently the case won't fit the garnet red. Customer service told me that the garnet red buttons dimensions are off from the blue and white. Which makes me think if there is any case that would fit the garnet red, since the garnet red has differenet dimensions than the white and blue ones.
    08-15-2012 09:13 PM
  2. funkylogik's Avatar
    wow i hadnt heard that!! i seriously think theyr talkin crap lol il have to look at a pic but samsung did really well to keep ALL the s3s in every country on every carrier identical
    08-15-2012 09:18 PM
  3. FunkMasterJoe's Avatar
    I have the Speck Candyshell for my garnet red and it fits perfectly.
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    08-15-2012 09:21 PM
  4. Red Android's Avatar
    I thought the same thing, only difference between three S3 should only be the color.
    If you go on the Speck official website, the candyshell detail actually saids "◦Fits all Samsung Galaxy S III (does not fit AT&T's Garnet Red version)"
    Not to mention I emailed the speck customer service as to why the candyshell wouldn't fit the garnet red and this is what they replied with:
    "Im 100% sure about this, the dimensions and buttons are slightly different dimensions from the other phones. Not sure why, but they are! Hopefully we will have some cases soon."
    But if your candyshell speck fits your garnet red, I'll take a chance and order one.
    08-15-2012 09:30 PM
  5. jcp007's Avatar
    Samsung Galaxy S3 Case - Defender Series | OtterBox.com
    The Defender Blush colored case would look great and protect your phone from unanticipated conflicts with gravity.
    08-15-2012 09:46 PM
  6. funkylogik's Avatar
    id order one and return it if it doesnt fit. imagine how much it would cost samsung to make a phone with different button layout from the rest lol
    08-15-2012 10:05 PM
  7. FunkMasterJoe's Avatar
    Yeah that's odd. I bought mine at the AT&T store when I got my phone. They put the case on for me and I've taken it off and put it back on a couple of times. All ports show perfectly. Not sure why they're saying it doesn't fit.
    08-15-2012 10:24 PM
  8. SideKickM24's Avatar
    That's really odd that the case won't fit the Garnet. I also saw that the Candyshell specifically says it won't fit, glad I didn't buy one.
    I've got the Otter Box commuter in black and it looks darned sexy on the Garnet lol
    Still browsing for a couple other cases to switch things up a bit from time to time though.
    08-15-2012 10:26 PM
  9. Red Android's Avatar
    The commuter is another one of my case choice. But heres the thing, if the commuter can fit the garnet red, shouldnt the candyshell fit as well? Its not as if the commuter is really loose compared to the candyshell.
    08-16-2012 02:23 PM
  10. jcp007's Avatar
    Rugged case beats bumper or snap on anytime.
    08-16-2012 04:04 PM
  11. robliu88's Avatar
    i got my case from ebay for around $10 and it fits pretty good came with a free screen protector too ^ ^
    SAMSUNG GALAXY S3 i9300 WHITE RUBBER HARD CASE WITH BELT CLIP COVER FREE SP items in AccessoryRack store on eBay!
    08-17-2012 12:48 AM
  12. Red Android's Avatar
    Taking the leap and getting a candyshell. Now should I get the black or gray candyshell for my red s3?
    08-17-2012 05:44 PM
  13. funkylogik's Avatar
    black
    08-17-2012 06:50 PM
  14. funkylogik's Avatar
    actualy gray will maybe make the red pop more
    08-17-2012 06:51 PM
