1. pcguys's Avatar
    What's up with that?
    ---Sent from the most advanced android mobile super-computer on the planet: the Samsung Galaxy S3 on AT&T, featuring simultaneous voice & data and speedy 4G!!!
    08-22-2012 01:42 PM
  2. NickLippert's Avatar
    Do you have your phone set to keep the screen on if you are looking at it?
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    08-22-2012 02:35 PM
  3. pcguys's Avatar
    Smart stay is unchecked
    08-22-2012 02:47 PM
  4. Tkbredx's Avatar
    Might be the song that tells it to scroll through the tabs when you tilt your phone. Try unchecking that and see if it still uses the sensor.
    If not then don't use chrome when you're in the bathroom
    08-22-2012 02:57 PM
  5. pcguys's Avatar
    If you mean unchecking "enable tilt scrolling" in developer options, I just did - good suggestion.
    mike
    08-22-2012 03:01 PM
  6. funkylogik's Avatar
    id like to know this. do any of the other browsers use view sensor or is it chrome specific?
    08-22-2012 03:07 PM
  7. mc_gusto's Avatar
    What app is that? I looked for app sicker in play store. I didn't see anything.
    Sent from my SPH-L710 using Tapatalk 2
    08-22-2012 04:41 PM
  8. funkylogik's Avatar
    i think App Sucker is part of the Gsam battery app mate
    08-22-2012 05:06 PM
  9. pcguys's Avatar
    Gsam battery monitor
    08-22-2012 05:12 PM
