1. okbow68's Avatar
    Ok so I buy a USB to go cord awesome. I have a micro sd reader awesome. I hook up the micro sd via this set up and the phone recognizes it as USB drive A. I can see the files on the card. What I can't figure out how to do is copy files from the phone to this micro sd or vice versa. There is space on the card and I have USB debugging checked. What am I doing wrong guys? Oh yeah I have some avi files on the card and the phone says it cannot play those for whatever reason. Thanks for the help.
    08-23-2012 07:37 PM
  2. funkylogik's Avatar
    using the MyFiles app on your phone you can move files from internal to the external sd. only media though.the phone wont read apps from that
    08-24-2012 03:30 AM
  3. okbow68's Avatar
    Ok but why can I not copy files either way from the phone to the micro sd via the usb to go or vice versa, any file not just media files i am talking documents etc.
    08-24-2012 09:28 AM
