What does sync toggle do in notification center
Turn on sync for emails, dropbox, Google chrome, anything else that can sync . In the back ground
Is it killing my battery? There is no way I can go through 80% in 2 hours.
Sent from my SGH-I747M using Android Central Forums
If you are like me and have 3+ emails with Facebook, dropbox, and more then probably. Especially if you don't have them set to sync periodically and just have them syncing every minute.
Are you talking screen on 2 hours? Cause that's good battery life with the screen on for 2 hours.
No that is me responding to a text or googling something
shift that battery life is terrible mate. i can browse for far 2hours and drop 50%.
i doubt that sync is the problem. get the GSam app and use that for a few days to see whats chewing the battery
Did you check to see exactly what is eating up your battery?
Sent from my SCH-I535 using Android Central Forums
araelbenjie
