- I like the idea of the power save mode. I am trying to decide if I should leave power save mode on all the time and only turn it off when it's necessary like playing a game. Or leave it off all the time and only turn it off when I won't have access to a charger for a long time.09-05-2012 08:44 AMLike 0
- It's a good feature to have when your phone is close to dying. But I can't bring myself to use it any times other than that. I mean the S3 is such a great phone, it's smooth and fast, and power saving mode just rids of those elements of the phone.
Sent from my Samsung Galaxy SIII09-05-2012 08:55 AMLike 0 - What I was doing was leaving power save mode turned on with only the CPU throttling on all the time. But I'm thinking of turning power save mode off unless I don't have a charger nearby. And in power save mode turn on CPU throttling, reduce screen frame rate, and dimming the browser back light.09-05-2012 10:01 AMLike 0
- I don't see a usage difference but I do know my GSIII doesn't do 15hrs on a single charge since I toggled off cpu throttling.
I made that choice cos I want mad speed even though I seldom call the device out.
Sum up, if you're a regular user leave power save mode on. The extra 2 or 3 hrs battery life is worth it
Sent from my GT-I9300 using Android Central Forums09-05-2012 10:24 AMLike 0 - Well I almost always have a charger available. I have one at home, at work, and in the car. There is the occasion when I won't have a charger available for a little while. Like shopping or something. So I don't need it to last 2 or 3 days. Just can't have it dying every 3 hours. But it seems like that isn't going to be a problem.09-05-2012 12:01 PMLike 0
- Nope, you would have to try really hard to kill it in 3 hours, but over time the battery will wear out if you are constantly killing it and recharging it. Contrary to popular belief, just because you fully deplete a Lion battery doesn't mean it will last longer. They do have a limit to charging cycles. But if you can get a new battery every 1.5 years or so then that does not matter if you have to charge it daily, plus with a recovery that allows you to clear the battery stat memory, you can squeeze a little more lifetime out of them.09-05-2012 12:13 PMLike 0
- AlmeuitModerator Team LeaderI still get really good battery life but if this feature helps more I would like to use it. I know I won't use it when at work streaming music and browsing the net but I would like to maybe use it those times where I am barley using the phone except for maybe some texting and a call here or there (out with friends, relaxing at home on the pc... Etc.)
So just curious who uses it and would suggest it? Would it help save a good amount of battery if I use it as described above? Thanks in advance for any advice
Sent from my SPH-L710 using Android Central Forums09-05-2012 05:07 PMLike 0 - I think it saves a good amount. I don't think it would double it or anything.
I'm going to try only using power save mode when I don't have a charger nearby. Or won't have one for a while.09-05-2012 06:11 PMLike 0 - I've been using the phone with power save for a while because I forgot to turn it back off. The phone was going Ok but recently it started stuttering a bit. TouchWiz has crashed a couple times. I'm going to try and turn power save off and see what happens.10-03-2012 06:16 AMLike 0
- power save off while usin s3 as a smartphone.
powersave on while usin it as a dumbphone.. simples
also, change the settings so that it only underclocks the processor. the rest can be changed manualy
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess10-03-2012 06:41 AMLike 0 - My typical weekday consists of my phone sitting at my desk for 8ish hours with no 4G. I browse some and text dome but that's it. Evenings I play games and watch YouTube. Weekends are a mix of the 2.
What do you consider smartphone activities? Because what I described sems like dumb phone stuff.10-03-2012 07:05 AMLike 0 - I checked screen power saving and cpu underclock. But I'm gonna leave power save off until it's needed. I don't have a brightness bar in the notification bar. But I can lower the browser brightness manually.10-03-2012 09:51 AMLike 0
while i use it as a smartphone i wana have the full whack.
when im out with friends (just back from court and pub) i have it on power saving but only affecting the cpu (i love haptic feedback and it was sunny so needed high brghtness)
now that im home, i have the quad core runnin at 1.4ghz
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guesstypinghairyape likes this.10-03-2012 10:08 AMLike 1 - No worries. Not patronizing at all. So basically you put it in power save mode when it's gonna be in your pocket and not in use for a while (while you're with friends) and off when it's gonna be used more?funkylogik likes this.10-03-2012 01:52 PMLike 1
Sent from my GT-I9300 using Android Central Forums10-03-2012 04:50 PMLike 0 - Those who have power save mode off, what % does the android system show? Mine went up a few points after turning off power save mode10-03-2012 09:39 PMLike 0
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess10-04-2012 06:52 AMLike 0 -
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess10-04-2012 06:54 AMLike 0 -
- I've been running with power save mode off and I do notice a bit of a decrease in battery life. But I don't think it's anything near 1 or 2 hours less. However I don't know that I've noticed a large increase in performance. Where would I see the difference in performance? Scrolling or home screen swiping?10-05-2012 02:49 PMLike 0
- Forum
- Samsung Android Phones
- More Samsung Phones
- Samsung Galaxy S3
Power save mode
