1. khirsh's Avatar
    I bought both the QCell 4200 mAh and Hyperion 4200 mAh extended batteries for the Samsung Galaxy S3. They both work fine (still not sure which one works better), but I can't seem to find an external charger that the batteries will fit in. (I have the Samsung external charger and the batteries don't fit.) Anyone know of an external charger that will work with these?
    09-06-2012 09:15 AM
  2. GK3K's Avatar
    You've misunderstood. He/she is not looking for a phone charger, but an external battery charger.
    KHIRSH: This charger works great with the larger aftermarket batteries: https://www.amazon.com/dp/B008JJFKN6...cUvbUpU2147317
    I'm using it with an Hyperion battery and it fits perfectly. Charges it rather quickly, too.
    Good luck!
    09-11-2012 11:22 AM
