09-28-2012 05:13 PM
57 123
tools
  1. deanodrums's Avatar
    certain apps have to wake the phone, say to give notifications etc
    kernal, to my understanding is the big chunk of firmware that controls the phones deepest functions (hope someone can correct me lol)
    doubt id use juice defender as i tend to control whats usin up power manualy but im sure its good for some people.
    have you ever looked into data use in settings and selected a certain app, theres a pie chart showing data used in foreground/background... for the apps that i feel dont need background data, i disable it to save battery
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    I like the gsam app. Shows me more than juice defender. I just haven't got around to getting rid. I do use the data use and I have set most things to when I am connected to WiFi. So while I am at work it doesn't suck the battery life to much. I use WiFi at home mainly. I have just upped mg data usage to 2gb for an extra 2 so I can watch TV or you tube while at work. Saying all this I'm not much for one in changing a lot of the stuff on my phone. I'd just like it to work out of the box and do a few simple add on here n there. I'll leave All the changing to you guys
    Sent from my GT-I9300 using Android Central Forums
    funkylogik likes this.
    09-28-2012 05:53 AM
  2. davidnc's Avatar
    I also been using GSam Battery Monitor Pro when it was called Bad Azz Battery Monitor( I dont leave the notification icon toggled on)
    Also CPU Spy is good teamed up with it .Thats why I use both
    09-28-2012 06:08 AM
  3. deanodrums's Avatar
    What does the CPU spy do mate? Sorry for the ignorance of my question I am a little less intelligent on these things.
    09-28-2012 06:41 AM
  4. funkylogik's Avatar
    mate is it an o2 contract youre on? u checked out Giffgaff.com? my average data use is 20gb a month.
    im on Three but if u get a good o2 signal n data speeds, u should check out giffgaff
    09-28-2012 03:46 PM
  5. deanodrums's Avatar
    Jesus! 20gb!!!!!!!!!!! Yea I am on an ok co tract. The most they do is 2gb. Signal I get is average while I am at home so j use WiFi. But ifbivwanna surf I use my iPad.
    09-28-2012 03:54 PM
  6. funkylogik's Avatar
    im on Three p+g, 15 for unlimited data, 3000txt, 300mins.
    giffgaff runs on o2, its just went from 10 to 12qid unlimited data, unlimited text, 250mins. it doesnt have a call centre, its online forums and u get "payback" for helping noobs and introducing folk to the network. in a 6month period i earned 160 just by doing the same as i do on this forum lol i just keep a giffgaff sim active to still earn payback (3 data is like 2ce as fast) but ive heard o2 are gettin 4g?
    09-28-2012 04:16 PM
  7. deanodrums's Avatar
    I am not sure about 4g at the moment. I am in a 24 month contract so it will be a while till I get something new. A lot of people say get a sim only and then buy the phone outright. Then you have the choice to update your phone as and when you please :thumbup:
    09-28-2012 05:13 PM
57 123
