I don't really like widgets either lol
If it's between a widget and an icon in the notification bar I'd choose the icon.
I have just got this app and I air t got a clue what the eff it means. Any help?
Sent from my GT-I9300 using Android Central Forums
Sorry for my typo. That should of said suckers instead of waters. What that's about I dunno. Yea I have been playing around with the gsam. Seems a good app. I have juice defender aswell.
certain apps have to wake the phone, say to give notifications etc
kernal, to my understanding is the big chunk of firmware that controls the phones deepest functions (hope someone can correct me lol)
doubt id use juice defender as i tend to control whats usin up power manualy but im sure its good for some people.
have you ever looked into data use in settings and selected a certain app, theres a pie chart showing data used in foreground/background... for the apps that i feel dont need background data, i disable it to save battery
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
I also been using GSam Battery Monitor Pro when it was called Bad Azz Battery Monitor( I dont leave the notification icon toggled on)
Also CPU Spy is good teamed up with it .Thats why I use both
I like the gsam app. Shows me more than juice defender. I just haven't got around to getting rid. I do use the data use and I have set most things to when I am connected to WiFi. So while I am at work it doesn't suck the battery life to much. I use WiFi at home mainly. I have just upped mg data usage to 2gb for an extra ?2 so I can watch TV or you tube while at work. Saying all this I'm not much for one in changing a lot of the stuff on my phone. I'd just like it to work out of the box and do a few simple add on here n there. I'll leave All the changing to you guys
mate is it an o2 contract youre on? u checked out Giffgaff.com? my average data use is 20gb a month.
im on Three but if u get a good o2 signal n data speeds, u should check out giffgaff
