1. deanodrums's Avatar
    I'm not sire is there is a thread for this topic. So I thought I'll do one anyway.
    This could be useful for everyone and people who like are new to android and Samsung phones.
    So basically. What do you guys recommend to have a smoother s3. Your recommended apps,launchers etc.
    I am still finding my way around my s3 and eventually I will get there.
    So over to you guys
    Sent from my GT-I9300 using Android Central Forums
    09-16-2012 08:36 AM
  2. cyanogen-man's Avatar
    Do your research about rooting and an cyanogen mod with Nelly bean it removes all that touch wiz BS and makes it smoother but if you want to stay stock that's respectable
    INSPIRE AOKP ICE COLD SANDWICH ROM
    09-16-2012 08:48 AM
  3. funkylogik's Avatar
    i recommend trusting the phone to handle its RAM efficiently, dont worry about killing apps or anything. mine scores higher in Quadrant benchmark (phone test app) when my ram is nearly all being used
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess
    09-16-2012 10:06 AM
  4. HOLLYWOODANT215's Avatar
    So over to you guys
    First thing u do is go to settings developer options put animation and transition speed off if u want is super fast or put it on 2 for real smooth iphone like transition...
    oma1340 likes this.
    09-16-2012 11:10 AM
  5. deanodrums's Avatar
    This is good stuff. Not only will this be helpful to myself but to others.
    09-16-2012 11:59 AM
  6. funkylogik's Avatar
    not sure if this speeds anything up but i always disable the bloatware and system apps that i dont use (ONLY disable the apps visible in app drawer and dont disable Messaging or any sms app you use wont work)
    09-16-2012 01:30 PM
  7. deanodrums's Avatar
    Ok if possible could you list the ones you have disabled? If that it's not to much trouble? I have disabled most of the apps I don't use or will need.
    09-16-2012 03:42 PM
  8. funkylogik's Avatar
    ok, ill see if i can fit em in one or two screenshots mate. i have an unbranded phone so there was no carrier bloat...
    09-16-2012 03:58 PM
  9. deanodrums's Avatar
    Yea mine is as well. From nearly all the posts I've seen your s3 is in my eyes the exact same as mine. Unbranded international. I do have another question. I may start it in another post but I'll ask here to. When I restart my phone,I do that from time to time, I get a message at the bottom of the screen saying unable to download. Please try again later. Any ideas of where to start looking?
    09-16-2012 04:08 PM
  10. funkylogik's Avatar
    ive no idea man, never had that message. do u use a torrent app or anything?
    man i took 5 screenshots of my disabled apps but the AC app wont let me post em. il try later mate
    09-16-2012 04:13 PM
  11. deanodrums's Avatar
    Yea I have an app called gTunes music. Pretty good app cheers man thanks for your help. I pretty much think I have disabled all bloatware. The maps I don't use so I disabled that.
    09-16-2012 04:42 PM
  12. funkylogik's Avatar
    yeah me too coz im sick of it starting itself. il just enable it whenever i need it. i disabled all the "S-" apps lol
    dont know why these screenshots arent uploading. it says theyr wrong dimension but ive uploaded 100s of screenshots...
    yeah gtunes is good man, tTorrent is GREAT. was just wondering if it was gtunes causing that message if the app starts on boot...
    09-16-2012 04:49 PM
  13. deanodrums's Avatar
    I think its something wrong with ac as I have trued to update my profile but says I'm not connected to the server.
    That's probably why
    09-16-2012 04:55 PM
  14. funkylogik's Avatar
    yeah im gettin something like "no reply from server"
    09-16-2012 05:33 PM
  15. funkylogik's Avatar
    if u wana pm ur email ill send the screenshots if u like but i basicly only disabled stuff i understood that was visible in app drawer. i remember someone posted a link ages ago to a list of whats safe to uninstall
    09-16-2012 05:36 PM
  16. deanodrums's Avatar
    I have also seen a post about what was safe to uninstall. But I didn't take note of it. I will have to trudge through the forum when on a pc and see if I can find it.
    09-17-2012 07:25 AM
  17. funkylogik's Avatar
    let me know if u find it bud
    09-17-2012 08:06 AM
  18. Roffles's Avatar
    You MUST root and install an ad blocker. It makes loading full desktop sites on chrome lightning fast and also all the ad supported apps run smoother with less distraction. Also, I find Nova Launcher to be an overall smother and more functional launcher than the stock Touchwiz UI.
    09-17-2012 03:34 PM
  19. deanodrums's Avatar
    As I'm new to this I think I'll leave it as it is. Too scared to mess it up. Haha. Though I will have a look at nova. Thanks for your suggestions.
    09-17-2012 03:55 PM
  20. lbkiml's Avatar
    I don't know about everyone else, but my S3 was smooth out of the box...
    TW or Nova, didn't matter. Though I chose Nova (even though there are trade-offs between the two)
    09-17-2012 04:01 PM
  21. deanodrums's Avatar
    I am used to TW but no harm in looking for others. Cheers.
    09-17-2012 05:05 PM
  22. funkylogik's Avatar
    yeah ad block is great for ad's in apps.
    theres a free add-on for Firefox browser that aparently blocks online ad's
    09-17-2012 05:11 PM
  1. SD card recommendation for S3?
    By javier180 in forum T-Mobile Galaxy S III
    Last Post: 09-20-2012, 10:07 PM
  2. Recommendations for Gym Notebook?
    By sjuranic in forum Android Apps
    Last Post: 05-26-2010, 12:16 PM
  3. Recommendations for stereo headsets with media buttons
    By KrazyRogue in forum Motorola Droid
    Last Post: 02-23-2010, 02:39 PM
  4. Recommendation for task management, something unobtrusive
    By jankyhanky#WP in forum Android Apps
    Last Post: 01-08-2010, 03:45 AM
  5. Use "Action" Mode for FAR BETTER Photo Results!
    By chrislitzkow in forum Motorola Droid
    Last Post: 11-16-2009, 11:34 AM
