1. XChrisX's Avatar
    In the beginning I had no problems at all with doubleTwist desktop app for the Mac. But now it is completely unusable. It freezes every time it opens, and I'm always having to force close. I wish there was another alternative that was more reliable, but this seems like the closest to iTunes I'm going to get. When it works it seems to be a decent app, then only problem is getting it to actually work. Any suggestions here? I always have doubleTwist running on my S3 when trying to sync, and still nothing.
    09-22-2012 09:30 AM
  2. artofdesign's Avatar
    You can use Kies to transfer music.
    09-22-2012 11:51 AM
  3. XChrisX's Avatar
    Thanks, I will try that out. After the mountain lion update today it seems like the problem has been fixed. Also after a quick Google search it seems like I am not alone with the problem. Many different speculations arrived, but I think it was just a compatibility issue with ML. Thanks for the advice!
    09-22-2012 06:13 PM
  4. jneusch's Avatar
    iSyncr works great for me. Syncs playlists, photos, vids, etc. I set up an automater to move pics to iPhoto photo stream every time it syncs. It is 2 way sync as well and updates play counts and music purchased on your phone.
    09-23-2012 08:38 AM
  1. Problem with nook for aneroid app
    By hdflhx in forum Amazon Kindle Fire
    Last Post: 11-29-2011, 05:46 PM
  2. Problems Restoring Files With TiBu for Update
    By bondguy399 in forum Motorola Droid X
    Last Post: 12-27-2010, 02:19 PM
  3. Replies: 1
    Last Post: 12-06-2010, 04:22 AM
  4. Replies: 1
    Last Post: 11-16-2010, 02:32 PM
  5. DoubleTwist for Mac question?
    By groundkontrol in forum Android Apps
    Last Post: 08-04-2010, 09:32 PM
