09-24-2012 10:19 PM
47 12
tools
  1. Soundtrack to Chaos's Avatar
    I'm very interested in purchasing this app and just have a few questions about it if anyone has it, thx
    On my Samsung galaxy s3 running android 4.0
    Because unlike ios, i keep my apps in app drawers, and not in infinite cluttered homescreens
    09-22-2012 10:29 AM
  2. funkylogik's Avatar
    whats it do mate? (sorry am so lazy lol)
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess
    09-22-2012 11:21 AM
  3. Soundtrack to Chaos's Avatar
    It can turn on your screen, turn off, launch apps play and pause music by waving your hand in front of the screen
    But I wanna know how much battery it runs up during use
    09-22-2012 01:07 PM
  4. funkylogik's Avatar
    does it use prox' sensor or camera?
    i found an app that used either prox or light sensor, cant remember, to turn the phone off which would be great for use with a flip case or just puttin phone in pocket but it was too sensetive so touching status bar turned sceen off
    09-22-2012 01:33 PM
  5. funkylogik's Avatar
    EDIT have u tied the free version? check battery drain and then decide
    09-22-2012 01:36 PM
  6. Tkbredx's Avatar
    Seems cool. I always thought about getting it as well. Let me know how you like it if you do get it
    09-22-2012 03:13 PM
  7. Soundtrack to Chaos's Avatar
    Yea, it uses the proxy sensor
    09-22-2012 03:18 PM
  8. Soundtrack to Chaos's Avatar
    The free version's features only work with music
    The paid versions allow you do launch apps and turn on and off the screen etc
    09-22-2012 03:18 PM
  9. Soundtrack to Chaos's Avatar
    Yea, ill let you know, just trying to figure out if it will drain the battery before a purchase
    Got to get a Google gift card to buy it too
    09-22-2012 03:19 PM
  10. Tkbredx's Avatar
    Yeah. I understand. They should have like a 3 hour return policy to let you try out stuff like that. But based on the stars, comments, and number of updates I'd say the dev is pretty reliable and it shouldn't drain battery too much
    09-22-2012 03:26 PM
  11. funkylogik's Avatar
    return policy is crap man. im not allowed to suggest it on here but I'D sideload a pirate version to test it and THEN buy if the dev' deserves it
    09-22-2012 03:28 PM
  12. Soundtrack to Chaos's Avatar
    Yea I remember I bought an amazon app a while back for 2$ called agile lock, played with it for 10 minutes and uninstalled it because I had to unlock my screen twice to use it, lol
    09-22-2012 03:31 PM
  13. funkylogik's Avatar
    right ive just downloaded it so il play with it when phones charged and show u battery stats.
    bear in mind its probably not an up to date version
    09-22-2012 03:32 PM
  14. Soundtrack to Chaos's Avatar
    Thanks alot, and tell me if you like the app
    funkylogik likes this.
    09-22-2012 03:44 PM
  15. funkylogik's Avatar
    oh mate it is very good.
    so far i only have "hovver" set to turn phone off and it works by closing my flip case or putting phone in pocket yet touching status bar doesnt affect it. ill give it an hour and check battery stats with it mostly idle but so far its a defo KEEPER
    only problem i can see is that it also switches screen ON which would be big battery killer, ill have a play with settings...
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    09-22-2012 06:24 PM
  16. Soundtrack to Chaos's Avatar
    Awesome, sounds good, thanks
    09-22-2012 06:59 PM
  17. funkylogik's Avatar
    ok SCRAP everything i just said!
    either the app or more likely the source i got it from has destroyed my phone
    posting from girls laptop.
    my screen stays on for like 2seconds at most... managed to uninstall app but its still f***.
    really dont wana factory reset.. anyone got any advice?
    how do boot s3into safe mode?
    not happy HELLP!
    09-22-2012 07:12 PM
  18. Soundtrack to Chaos's Avatar
    not happy HELLP!
    Wow, what happened? I don't know how to activate safe mode
    How could that happen, they said the app was developed on the GS3
    09-22-2012 08:01 PM
  19. funkylogik's Avatar
    it was a pirate version so lesson learned mate
    check out my "broke my phone HELP thread lol. in process of backing up as much as i can then factory reset
    id defo recomend buying the app though even just for the screen off function... read the s3 user reviews 1st though lol
    09-22-2012 09:09 PM
  20. Soundtrack to Chaos's Avatar
    Oh ok, hope everything goes well
    The app sounds badass tho, can't wait to get it, there are very few apps that do that screen on feature and the ones that do give you an ad or open the app that does it as soon as you unlock
    09-22-2012 09:16 PM
  21. funkylogik's Avatar
    hope the toggle isnt just screen off/on though.. id want either manual ON or a different gesture or it woult be constantly switchin on/off in my pocket lol.... plus id like to know batt' usage
    09-22-2012 09:23 PM
  22. funkylogik's Avatar
    phone fixed itself lol
    im waiting for someone else to try the genuine app before me though lol *looks at Chaos*
    09-22-2012 09:43 PM
  23. MangoPowah's Avatar
    I remember reading somewhere that Google Play allows a 15 minute refund period after you download an app. I haven't tried it myself, though...
    Sent from my HTC One X
    09-22-2012 09:47 PM
  24. funkylogik's Avatar
    exactly bro. its not long enough to test battery life.
    every app should have say a 7day trial app (not books or movies obviously lol)
    MangoPowah likes this.
    09-22-2012 10:05 PM
  25. Soundtrack to Chaos's Avatar
    Lol, i don't have money attached to my Google play account but I will out some soon
    09-22-2012 10:07 PM
47 12
  1. does anyone here have shadow guardian on your droid
    By add119 in forum Motorola Droid
    Last Post: 05-06-2011, 05:03 PM
  2. Does anyone else use the *spark homescreen?
    By TeeJayEss in forum Motorola Droid 2
    Last Post: 04-05-2011, 01:53 PM
  3. Replies: 0
    Last Post: 02-01-2011, 12:55 AM
  4. Does anyone still use the Sirius app? Questions...
    By cpolism in forum Android Apps
    Last Post: 12-11-2010, 02:07 PM
  5. Replies: 11
    Last Post: 12-10-2010, 01:18 PM
