I recently learned that I should not use a task killer such as advanced task killer to save battery.
Instead, I downloaded WatchDog Lite, a CPU monitoring device that shows how much CPU each app/task is using. Is it correct to say that the amount of battery a certain app takes up is proportional to solely its CPU utilization and not how much RAM/memory it is using?
For example, if a program is displayed as using 0.0% CPU and 100mb of RAM, does it mean that it's just idling in the background and not consuming any battery life?
Similarly, if I was playing a game such as Angry Birds or World of Goo, or using an App that does not have an exit button, and I hit the home button to return to home screen, is that good enough to close the program? When I hit the game again, the game restores to where I left off, so it seems like as if I only paused the game when I hit the home button. Is the game still taking up battery power in such a situation where I just minimized it using the home button? If so, then what is the proper way to shutdown the application?
Thanks.
Thanks.
