1. jamesino's Avatar
    I noticed today that Android System has been eating up about 20% of my battery and is constantly running between 3-6% CPU usage according to WatchDog. This has not happened on any previous days and i noticed that my battery dropped faster than normal.
    How much CPU does Android System take on your phones during regular operations and how much overall percentage of battery is it normal for it to consume?
    10-03-2012 04:14 PM
  2. GSDer's Avatar
    I don't run Watchdog but here's the standard battery information:Android System eating up a bunch of battery-uploadfromtaptalk1349310659628.jpg
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    10-03-2012 07:31 PM
  3. jamesino's Avatar
    With 4G turned on and Gmail set to sync, how many percent drop per hour would you say is normal if you don't touch your phone at all during that hour?
    10-03-2012 07:33 PM
  4. GSDer's Avatar
    Uh, you can be the judge.
    Before:Android System eating up a bunch of battery-uploadfromtaptalk1349316866107.jpg
    After:
    I turned WiFi off; data on; had all the sync stuff turned on; turned the screen off.
    Attached Thumbnails Android System eating up a bunch of battery-uploadfromtaptalk1349316893651.jpg
    10-03-2012 09:16 PM
  5. funkylogik's Avatar
    u gota remember its a percentage.. everything has to add up to 100% so if u use say the screen less one day, other things % will go up
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    10-04-2012 05:35 AM
  1. Poor battery life, android system eating it all up?
    By ireknole in forum Sprint Galaxy S III
    Last Post: 01-24-2013, 01:36 PM
  2. "Android System" have lots of apps - cause of battery drain?
    By striders in forum Verizon HTC Thunderbolt
    Last Post: 05-13-2011, 01:48 PM
  3. Replies: 10
    Last Post: 12-20-2010, 09:47 AM
  4. Now my android system is using 54% of battery...yikes!
    By hawaiijedi in forum HTC EVO 4G
    Last Post: 11-17-2010, 03:44 PM
  5. battery use shows android system using 65% of my battery
    By bcat73 in forum Verizon Droid Incredible
    Last Post: 05-05-2010, 07:41 AM
