1. vic_singh's Avatar
    Do I need it to connect to Kies?
    Cause I tied connection using another cable and it wouldn't work
    Sent from my SGH-I747M using Android Central Forums
    10-05-2012 12:53 PM
  2. smooth4lyfe's Avatar
    No you can use any GOOD QUALITY USB Cable...some cables are cheap and wont work...if your getting another, I suggest one with a gold tip
    10-05-2012 12:56 PM
  3. funkylogik's Avatar
    aparently non samsung ones charge slower but for data transfer theyre fine (ive used a kindle one)
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    10-05-2012 01:12 PM
  4. Trees's Avatar
    I'm using BlackBerry and Motorola cables from my old phones. Have not run across any issues that I can trace back. If I remember correctly my S3 didn't come with a new cable so glad I can reuse the ones I have.
    10-05-2012 10:51 PM
  5. Srambo217's Avatar
    Just use Wifi File Explorer and uninstall Kies
    Sent from my SCH-I535 using Android Central Forums
    10-07-2012 11:26 AM
  6. richardpandy's Avatar
    Don't forget that not all USB ports on the computer are the same. For instance, my top USB Ports won't detect the phone/kies when plugged in but it will charge. The ports on the front of the computer and rear of the computer work with everything. Might just have to chance which port it is plugged in to.
    10-07-2012 12:13 PM
  1. Incredible usb cable special?
    By Feldhege in forum Incredible Accessories
    Last Post: 09-15-2010, 12:47 PM
  2. Cheap micro usb cables?
    By DrAndroid in forum EVO Accessories
    Last Post: 05-27-2010, 11:50 AM
  3. USB cable for connecting Incredible to computer
    By tpspeier in forum Verizon Droid Incredible
    Last Post: 04-23-2010, 09:48 PM
  4. Moment and USB cable
    By bostonaudi in forum Samsung Moment
    Last Post: 02-02-2010, 11:43 AM
  5. Replies: 4
    Last Post: 01-08-2010, 10:41 AM
