1. skohler's Avatar
    I just got a Galaxy S3 through Veizon, which is my first android phone (runs 4.0). I have set it to sync using ActiveSync with my Exchange 2010 server at work, where I use Outlook 2010. My Outlook is set for "file as" Last name First name. I have set Contacts on my Galaxy to "List by" Last Name and "Display contacts by" First name. These settings match the way my Outlook works.
    Now the problem: When I add a new contact on the Galaxy, I have no "file as" option. When the contact syncs back to Exchange, it winds up sorting by first name. If I edit the contact in Outlook, the "File as" parameter shows firstname, lastname. In other words, a name like "Aaron Zygote" displays in the A section instead of the Z section, and I have to manually change the "File as" setting on each new contact in Outlook to fix this.
    What am I missing? Thanks for any help you can provide.
    10-18-2012 06:19 PM
  1. Can Android open windows files?
    By kriEv in forum HTC Hero
    Last Post: 06-13-2012, 10:28 AM
  2. Can an Android phone be used as a WiFi only device?
    By MrBigFeathers in forum General Help and How To
    Last Post: 10-13-2011, 07:40 PM
  3. Does anyone else see this as a problem?
    By caveman663 in forum HTC EVO 4G
    Last Post: 06-22-2010, 02:51 PM
  4. Touchdown for exchange and Froyo 2.2 problem
    By tpierce67 in forum Android Apps
    Last Post: 06-12-2010, 12:41 PM
  5. Android & Exchange?
    By smccloud in forum General Help and How To
    Last Post: 12-23-2009, 04:27 PM
