Damn, you're right! I'm addicted to Twitter lol so yes, I check it every two minutes. Thanks for the reply.
You might wanna download the Falcon twitter widget and just refresh that every once in a while instead of opening the app
I used to use physical buttons, and then I found button savior
-S. T. C
Sent from my rooted, debloated CM10 jelly bean 4.1.2 Samsung Galaxy S3 #LikeABo$$
I can give a better opinion if you post your screen usage details, but from the look of it you were using your device quite a bit on this charge.
Totally normal, if you want an extra bump check out Greenpower Premium or JuiceDefender in the app store.
Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
ive never really had faith in those types of apps mate. what sacrifice do you make for the extra batt' life?
ps OP try GSam Battery monitor for a closer look at whats using your battery, its a pretty good app and widget
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
No real sacrifice, it simply toggles off your 3g/4g when your screen is off. Only issue you might have is that it could cut the data stream to apps like Play Music or Pandora, but Greenpower (for example) has a whitelist which prevents the app from killing the connection when you specific app is in use.
You don't need 3g/4g to receive text messages and phone calls.
will this stop me getting push notifications though mate?
It shouldn't. I still get Instagram and Android Central notifications.
cool. tbh all id use it for is to turn off mobile data while screen is off but id have to set a whitelist (payed version)
does the app use little enough battery for it to be efficient for the one function ill use it for?
thanks man, ill prob just buy the payed version on payday for the whitelist.
sounds cool if im still getn push notifications.
dont a lot of sync things build up and then just flow as soon as the screen is switched on though defeating the purpose?
