1. garry1bowie's Avatar
    Guys, I'm new to Android so forgive me if this is a brain number. Had a look at my battery stats and I'm not sure if this looks good? Can you advise? Thanks.
    Sent from my GT-I9300 using Tapatalk 2
    Attached Thumbnails Does this look right?-uploadfromtaptalk1351069790022.jpg
    10-24-2012 04:10 AM
  2. plkevlar's Avatar
    Looks right to me, you constantly check your Twitter thing or are tweeting to it or whatever that twitter thing does and that requires the big *** screen to be turned on a million times a day. So big screen is first and plume would be second better check some battery saving settings though, you could be experiencing extra drain do to the anticipated motion or gesture feature of the phone
    Sent from my SCH-I535 using Android Central Forums
    sledge007 likes this.
    10-24-2012 05:17 AM
  3. garry1bowie's Avatar
    Damn, you're right! I'm addicted to Twitter lol so yes, I check it every two minutes. Thanks for the reply.
    10-24-2012 05:52 AM
  4. Soundtrack to Chaos's Avatar
    You might wanna download the Falcon twitter widget and just refresh that every once in a while instead of opening the app
    I used to use physical buttons, and then I found button savior
    -S. T. C
    Sent from my rooted, debloated CM10 jelly bean 4.1.2 Samsung Galaxy S3 #LikeABo$$
    10-24-2012 07:39 AM
  5. garry1bowie's Avatar
    Good shout! Thanks, I'll have a look at that.
    -S. T. C
    10-24-2012 11:08 AM
  6. plkevlar's Avatar
    Yea lol I'm not sure on how the twitter thing works cuz I don't use it but the constant on and off of the screen will take its toll on your battery. The only thing that drains it more than screen time is lack of service. That's my killer
    Attached Thumbnails Does this look right?-uploadfromtaptalk1351097044614.jpg
    10-24-2012 11:44 AM
  7. Srambo217's Avatar
    I can give a better opinion if you post your screen usage details, but from the look of it you were using your device quite a bit on this charge.
    Totally normal, if you want an extra bump check out Greenpower Premium or JuiceDefender in the app store.
    Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
    acuratly87 likes this.
    10-24-2012 12:39 PM
  8. acuratly87's Avatar
    Juice Defender (free) is showing a noticable increase in battery life. If it keeps over a day, I'll pop for the Ultimate! Thanks.
    10-24-2012 01:28 PM
  9. funkylogik's Avatar
    ive never really had faith in those types of apps mate. what sacrifice do you make for the extra batt' life?
    ps OP try GSam Battery monitor for a closer look at whats using your battery, its a pretty good app and widget
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    10-24-2012 05:16 PM
  10. Srambo217's Avatar
    No real sacrifice, it simply toggles off your 3g/4g when your screen is off. Only issue you might have is that it could cut the data stream to apps like Play Music or Pandora, but Greenpower (for example) has a whitelist which prevents the app from killing the connection when you specific app is in use.
    You don't need 3g/4g to receive text messages and phone calls.
    funkylogik likes this.
    10-24-2012 05:36 PM
  11. plkevlar's Avatar
    One more battery saving technique for you would be the removal of hd widgets. I would use beautiful widgets if battery is a concern cuz as soon as hd widgets gets installed on a device if mine I lose like six hours of battery that day.
    10-25-2012 07:10 AM
  12. xKrNMBoYx's Avatar
    Did you ever turn your phone off? My brother's S2 had a similar statistic. The battery was at around 70% but it said the Phone Run Time was only 2 hours and 30ish minutes. Then he told me he had his phone turned off. Otherwise you may be using your device a bunch. Two days ago my S3 lasted 1 Day 18 Hours. Probably because I realized facebook and Kaotalk likes to run in the background and I closed them.
    10-25-2012 11:27 AM
  13. funkylogik's Avatar
    will this stop me getting push notifications though mate?
    10-26-2012 08:20 PM
  14. Srambo217's Avatar
    It shouldn't. I still get Instagram and Android Central notifications.
    10-26-2012 08:28 PM
  15. funkylogik's Avatar
    cool. tbh all id use it for is to turn off mobile data while screen is off but id have to set a whitelist (payed version)
    does the app use little enough battery for it to be efficient for the one function ill use it for?
    10-26-2012 08:34 PM
  16. Srambo217's Avatar
    The app doesn't even show up in my battery stats, so I can only imagine it uses next to no battery life to operate.
    Just try out the free version, you'll notice a difference. If it's significant enough than grab the paid version. I don't regret it. I use it on all my android devices.
    10-26-2012 11:33 PM
  17. funkylogik's Avatar
    thanks man, ill prob just buy the payed version on payday for the whitelist.
    sounds cool if im still getn push notifications.
    dont a lot of sync things build up and then just flow as soon as the screen is switched on though defeating the purpose?
    10-27-2012 01:40 AM
  18. Srambo217's Avatar
    Perhaps. I couldn't give an opinion given I manually update most things like Twitter, Gmail, ect. The only reason I get notifications from AC and such is because I'm too lazy to toggle the notifications off lol.
    Those notifications are there when I wake up my device, and my 3G icon will 'reappear" within a second of waking up, so I don't specifically know why those notifications push. I imagine it's because it's a small ping and not pulling in mass amounts of data like 200+ tweets or several email messages.
    10-27-2012 03:52 AM
  19. Srambo217's Avatar
    Delete
    10-27-2012 03:56 AM
  20. funkylogik's Avatar
    yeah i generaly do things manualy. thats why ive never had faith in such apps but my screen is constantly on/off so i fancy it just for the data off function.
    might try the free one or a cracked version tomorrow and buy if i think its worth it.
    thanx man
    10-27-2012 04:01 AM
  1. Video Samples of 1080p video..How does this look.
    By u71n4444 in forum HTC EVO 4G LTE
    Last Post: 07-12-2012, 01:27 PM
  2. Does This Speed Test Result Look Right for a -83 dBM 4G Signal?
    By GNex Girl in forum Verizon Galaxy Nexus
    Last Post: 02-10-2012, 08:00 AM
  3. Does this sound right?
    By Littleairjordan1 in forum Verizon HTC Thunderbolt
    Last Post: 03-16-2011, 09:57 PM
  4. looking for custom theme and boot screen will donate to the dev who does this
    By blupit30 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-26-2010, 07:44 PM
  5. Why does this phone have so many problems?
    By bigk in forum Verizon Droid Incredible
    Last Post: 05-27-2010, 01:10 AM
