1. ralphter's Avatar
    I found a thread in another site where a guy disabled him Samsung account and disabled the Samsung apps that he didn't use and his battery life is way better unfortunately I can't find where I found it but I tried this method and I went from using 10-12% of battery overnight while in sleep mode to now using 2% it definetley works
    10-24-2012 11:03 AM
  2. Soundtrack to Chaos's Avatar
    I just cut off my wifi and data during sleep, I usually lose anywhere between 2 and 5% by the time I get up
    I used to use physical buttons, and then I found button savior
    -S. T. C
    Sent from my rooted, debloated CM10 jelly bean 4.1.2 Samsung Galaxy S3 #LikeABo$$
    10-24-2012 11:04 AM
  3. ralphter's Avatar
    If you cut off data what if a family memeber calls at 4 in the morning with a life threatening emergency
    10-24-2012 12:20 PM
  4. ralphter's Avatar
    Nvm I thought turning off data wouldn't let you make phone calls but I was wrong that must save alot of battery in that case
    funkylogik likes this.
    10-24-2012 12:41 PM
  1. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 09-07-2013, 12:03 AM
  2. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 08-09-2013, 10:57 AM
  3. Overnight Battery life
    By merid in forum Verizon Galaxy Nexus
    Last Post: 02-24-2012, 08:19 PM
  4. Battery life overnight and overall worse battery time...
    By bor999 in forum Motorola Droid X
    Last Post: 05-24-2011, 06:34 PM
  5. drastic overnight change in battery life
    By itsafuntime in forum Verizon Droid Incredible
    Last Post: 06-09-2010, 02:24 PM
