1. emathed's Avatar
    My battery doesn't seem to last very long. I'm wondering how long is a normal charge? I downloaded juice defender but dont know how to use it as far as I dont know what settings I shoukdr choose. I always exit after each app and I usually always clear my task manager. I leave the screen turned down quite a bit. Just not sure whats draining my battery so fast.
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    Attached Thumbnails What is a normal battery use?-uploadfromtaptalk1351187778449.jpg   What is a normal battery use?-uploadfromtaptalk1351187792747.jpg   What is a normal battery use?-uploadfromtaptalk1351187805071.jpg
    10-25-2012 01:56 PM
  2. spartanrob1's Avatar
    It get's better with time, at least a little. I haven't found Juice defender to be that much help for me. Currently, i'm at 69% with 5h 24m. Have not been on wifi at all as i'm at work. For me, the biggest drain seems to be when i'm in a poor LTE area (like my home). If your phone is new, i'm guessing that you are playing with it a lot also, that obviously doesn't help the battery. Lot's of threads here talking about battery life.
    emathed likes this.
    10-25-2012 02:03 PM
  3. geekymcfly's Avatar
    If you just got a the phone I would've charged the phone completely for the first usage and depleted it to zero and recharge back to 100%. Check out one of the battery threads.
    "all animals are created equal but some animals are more equal than others" animal bylaws- animal farm
    emathed likes this.
    10-25-2012 02:07 PM
  4. Deadly_Poison630's Avatar
    i found juice defender and other apps similar has caused more problems than fix them. Normally i get about 12+ hours easily now that i turned off that sprint connections setting. Like others said, i would look at some of the battery threads for tips
    emathed likes this.
    10-25-2012 02:16 PM
  5. junglejunkie's Avatar
    I am usually off charger from 6:30am-10pm with around 2 hours of screen time (give or take) and my battery is usually at 25-35% by the time I'm ready to plug it in at night (WiFi/GPS on). But I am also in an area where I do not have 3/4G and I am on WiFi for a majority of that time.
    emathed likes this.
    10-25-2012 02:46 PM
  6. emathed's Avatar
    Still wondering if my battery usage is good or not?
    Attached Thumbnails What is a normal battery use?-uploadfromtaptalk1351195153828.jpg
    10-25-2012 03:59 PM
  7. Almeuit's Avatar
    What is your screen on time?
    Sent from my Sprint S3 using AC forums
    10-25-2012 07:03 PM
  8. emathed's Avatar
    What do you mean?
    10-25-2012 07:17 PM
  9. emanuelm123's Avatar
    That doesn't look that bad if u look at just how much you've had ur screen on in those 4 hours so your battery might be normal
    Sent from my EVO LTE
    unlmtdRW likes this.
    10-25-2012 07:47 PM
  10. unlmtdRW's Avatar
    Yeah, that was my thought... I typically don't get much more than about 4.5 hours of screen time before I'm charging again.
    ... but then that also generally takes me about 36-40 hours to do, so it just seems like my battery lasts a long time.
    10-25-2012 10:13 PM
  1. what is condsidered normal battery life?
    By taskellusaf in forum Droid RAZR MAXX
    Last Post: 02-24-2012, 12:55 PM
  2. what is up with battery % / calibration
    By sinfony78 in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 04-04-2011, 08:27 PM
  3. What is your average battery life??
    By Forgetful in forum Verizon Droid Incredible
    Last Post: 03-15-2011, 11:45 PM
  4. What is draining my battery?
    By jherm04 in forum Motorola Xoom
    Last Post: 03-08-2011, 10:06 PM
  5. Is this normal battery life ?
    By OrderedtheEvo in forum HTC EVO 4G
    Last Post: 07-08-2010, 08:04 PM
