1. funkylogik's Avatar
    this is my 1st full (well down to 5%) discharge since JB and it doesnt look great tbh
    i know im not a normal user but compared to other days like this when the phones in constant use, this seems bad.
    wish id done a "before" shot...
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    10-25-2012 04:24 PM
  2. funkylogik's Avatar
    oops
    10-25-2012 04:25 PM
  3. Moez1210's Avatar
    How much on screen time? 0_o
    Sent from my GT-I9300
    bigdaddytee likes this.
    10-25-2012 04:32 PM
  4. funkylogik's Avatar
    58 percent of however long the phone was running mate lol (me bad at maths)
    10-25-2012 04:40 PM
  5. funkylogik's Avatar
    heres apps
    10-25-2012 04:41 PM
  6. funkylogik's Avatar
    everything looks normal percentage-wise though...
    10-25-2012 04:44 PM
  7. funkylogik's Avatar
    10-25-2012 04:46 PM
  8. GSDer's Avatar
    I don't know, Funky - that all looks perfectly reasonable. You had the screen on almost the whole time. I don't know what your screen brightness setting was, but that would be the only thing that you could do to stretch your time out - I mean, you had WiFi on and were using the phone pretty much the whole time.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    funkylogik likes this.
    10-25-2012 10:25 PM
  9. funkylogik's Avatar
    yeah between 10-5% as the evening progressed mate and i wasnt connected to wifi, just had it on coz google Now likes it on lol.
    i usualy get a bit longer with hard use like this.
    ive constantly got a decent 3g (hsdpa/hspa+) connection so i duno if having wifi on in background makes a diff'?
    (i dont have home wifi)
    10-25-2012 10:59 PM
  10. blade22222's Avatar
    If I'm not mistaken wifi constantly looks for hot spots in the background when it's on and not connected. Next time you run your battery down touch the screen tab in battery usage tab, I'd like to see how long your screen was on.
    Sent from my SCH-I535 using Android Central Forums
    10-26-2012 06:21 AM
  11. funkylogik's Avatar
    will do when im charged again mate. te battery actualy lasted well when i slept though and wifi only used .1% so it doesnt seem to be that....
    from memory though, the screen was on most of the time, it was a heavy use discharge. maybe im imagining it but unless im streaming, i usualy get a bit longer when im sat online for hours (dont have home broadband).
    i should really have recorded a test before JB to be sure.
    everything does look prety normal percentage-wise...
    10-26-2012 02:47 PM
  12. junglejunkie's Avatar
    If you are getting roughly 5-6 hours of screen on time you are doing great.
    10-26-2012 03:17 PM
  13. funkylogik's Avatar
    yeah, think its just placaebo effect mate.
    youre right.. also i was messin around with stuff more and maybe posting more as id just got JB
    cheers
    10-26-2012 04:47 PM
  14. funkylogik's Avatar
    tonight with same heavy use although ive been playin around with homescreen
    10-26-2012 10:06 PM
  15. funkylogik's Avatar
    suppose its fair enough.
    id do a test of the phone sleeping but i dont sleep for long enough
    10-26-2012 10:08 PM
  16. funkylogik's Avatar
    wow this is bit worse (actualy its not far off) although ive uploaded pics to fb and messed around with homescreen a bit
    Jellybean battery life?-uploadfromtaptalk1351338635327.jpgJellybean battery life?-uploadfromtaptalk1351338656054.jpg
    next full charge ill try wifi off just incase....
    next time GPS...
    10-27-2012 06:51 AM
  17. andrew5353's Avatar
    Me too, you need to turn off all of Google's location reporting and the cause of the biggest drain is Samsung Push. I disabled it and now enjoy normal battery life. If you use the Samsung app it will enable it again but who needs that app anyhow. My wife still has ICS and after 1 day 12 hours she still had 73 percent battery after lite use. Tell people about Samsung Push as the battery life is really annoying everyone.
    01-03-2013 01:29 AM
  1. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 09-07-2013, 12:03 AM
  2. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 08-09-2013, 10:57 AM
  3. Battery life worse after JellyBean?
    By harold42483 in forum Sprint Galaxy Nexus
    Last Post: 01-28-2013, 10:47 AM
  4. Best JellyBean ROM and kernel setup for battery life?
    By jlibis in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-01-2012, 05:40 AM
  5. Samsung Moment battery life
    By IIJBII in forum Samsung Moment
    Last Post: 03-21-2012, 08:48 PM
