1. shikano53's Avatar
    Hi,
    My wife and I picked up new SG3's yesterday. I got a 32GB my wife got a 16GB; her call.
    On my old Galaxy S there was a small icon that I had on my home screen called 'Active Applications' which you could tap and it would take you to a screen showing running apps where you could turn them off singly or collectively.
    Is there anything on the S3 that is similar? I have gone into settings and found something called Applicaton Manager but I can't find anyway to put it on one of my home screens.
    Any help or comments would be appreciated.
    Thank you in advance.
    Chris in RD, AB
    10-26-2012 11:25 AM
  2. Jao Ozaki's Avatar
    Hold down your Home button and you can access a Task Manager.
    As far as widgets go, id just download an App that does the job.
    geekymcfly and funkylogik like this.
    10-26-2012 11:32 AM
  1. Is there an easy way to roll back to the previous droid version?
    By leprechaun106317 in forum AT&T LG Phoenix/Thrive
    Last Post: 06-28-2012, 08:01 PM
  2. Is there a case equivalent to Iphones Exolife for the Nexus?
    By mrwax in forum Verizon Galaxy Nexus Accessories
    Last Post: 01-17-2012, 10:37 PM
  3. Is there an app similar to the Reminders on iOS 5?
    By chmcke01 in forum AT&T Galaxy S II
    Last Post: 12-05-2011, 05:24 PM
  4. Replies: 39
    Last Post: 01-04-2011, 07:41 PM
  5. Is there an Android Equivalent to...
    By WatermelonSlim in forum Android Apps
    Last Post: 04-26-2010, 09:07 PM
