1. gilbequick's Avatar
    Does anyone know how to get all of the holidays loaded into the calendar....without having to manually enter them all in? Can it be synced with Google somehow?
    Thanks!
    11-10-2012 06:01 AM
  2. ihatepineapple's Avatar
    personally. i grabbed google calendar from p.s. as i feel s-planner is a sack of...
    linked in UK & US holidays from somewhere or other and i have fb events. then added a calendar widget to my home screen.
    11-10-2012 07:15 AM
  3. leprechaunshawn's Avatar
    Open your calendar, go to Settings > Calendars > Check the box for US Holidays
    If you aren't in the US, I would assume the option is labeled to whatever country you're in.
    11-10-2012 07:36 AM
  4. gilbequick's Avatar
    That was it, thanks much.
    Now for the next question: My calendar only displays a line on the days that there are holidays on. I've seen where the actual name of the holiday is shown, for example on Thanksgiving it would say "Thanksgiving" not just show a line. How do I get the names back?
    11-10-2012 08:49 AM
  5. leprechaunshawn's Avatar
    Mine displays the holiday, so I'm not sure how to fix that problem. Hopefully someone else has a solution.
    11-11-2012 11:58 AM
  1. Need Exchange Calendar Help
    By Soccer Mom in forum Motorola Droid
    Last Post: 02-16-2014, 09:48 PM
  2. Calendar Help
    By 1Reaper in forum HTC EVO 4G
    Last Post: 01-05-2011, 12:58 PM
  3. Calendar help
    By little_bug in forum Verizon Fascinate
    Last Post: 10-01-2010, 11:01 PM
  4. Calendar Help PLEASE......
    By Oj467 in forum General Help and How To
    Last Post: 07-15-2010, 01:05 PM
  5. Calendar Help Please
    By jedisrus in forum HTC EVO 4G
    Last Post: 06-05-2010, 10:21 PM
