1. nbdiver's Avatar
    Does anyone else have this problem? When I am on a call and I get a call waiting call, I hit swap to answer the call then swap back to my original call. After this my screen still shows the other call is on hold and I don't have the ability to end it. If I hit end while picking up the second call it actually disconnects both calls. After this happens I have no ability to add a call and merge it as a conference call because the merge button is not available. It's still stuck on swap.
    Has anyone else noticed this? If so is there a fix? Thanks on advance for the help.
    Sent from my SCH-I535 using Android Central Forums
    11-16-2012 08:14 PM
  2. nbdiver's Avatar
    Anyone else have this problem?
    11-18-2012 11:25 AM
  3. GSDer's Avatar
    I've never added a caller to an existing call, so I can't offer any suggestions there.
    Regarding switching between callers - I've never figured out how to end one call while keeping the other in progress. I had this same problem with my previous Android phones - I think it's something inherent in the phone app design.
    Perhaps a 3rd party phone app?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    11-19-2012 05:21 PM
  4. nbdiver's Avatar
    anyone else have a solution to this problem. Its really annoying as I use my phone all day for work and the phone does not manage the calls very well when you are on a call and then answer call waiting.
    12-22-2012 01:10 PM
  5. adelcastillo78's Avatar
    The issue is not android, Its CDMA and how it handles multiple calls at the same time.
    If you ask someone in AT&T or T-mo, they won't have this issue
    12-22-2012 10:59 PM
  6. nbdiver's Avatar
    That is interesting so its a Verizon only problem? I'll have to ask my Verizon rep about any fixes then.
    01-17-2013 06:52 PM
  7. meyerweb#CB's Avatar
    Nope, Verizon and Sprint. This is how it's been handled on every Sprint phone I've owned, Android or otherwise. I don't think any fixes exist at the moment. If they ever migrate to voice over LTE, that would probably resolve it.
    01-18-2013 12:58 PM
  1. is there a way to view call history and time???
    By airtas in forum HTC Droid Eris
    Last Post: 03-26-2015, 05:50 AM
  2. call waiting and switching calls
    By anonymous239411 in forum Verizon HTC Thunderbolt
    Last Post: 05-13-2011, 04:06 PM
  3. 3 way and call waiting Can't hang up on 1 pers Incredible
    By jamesy in forum Verizon Droid Incredible
    Last Post: 06-26-2010, 02:35 PM
  4. CDMA/4G and call waiting
    By Darth Mo in forum HTC EVO 4G
    Last Post: 06-24-2010, 03:44 PM
  5. Calls, Facebook, and confusion
    By cklosowski in forum Motorola Droid
    Last Post: 12-24-2009, 09:41 AM
