1. XChrisX's Avatar
    So as of lately, it seems like whenever I get multiple sms messages at once from a single person or multiple people my phone locks up on me. The led still flashes green, but I have to hold the power button on the side down until the phone shuts off, and then reboot the phone entirely. Is anyone else having this problem? Is there a fix for it, or is it just me?
    11-17-2012 07:12 PM
  2. Soundtrack to Chaos's Avatar
    Uninstall then re install the app
    I've haven't had this issue, but I have had issues sending long text messages, make sure you turn on the option that makes the messages split into 160 words a piece, it helps
    funkylogik likes this.
    11-17-2012 07:36 PM
  3. smooth4lyfe's Avatar
    Try clearing the cache? Must be a memory issue
    11-17-2012 07:47 PM
  4. hell_on_heels's Avatar
    Must just be your phone. Try uninstall and reinstalling. I know it's a pain n the butt to redo everything. Make sure you clear cache and data before u uninstall it.
    O_o WISHING I HAD WAITED AND GOT THE NOTE 2, ANYONE WANNA TRADE? o>_<o~
    11-18-2012 12:50 AM
  5. XChrisX's Avatar
    Thanks for the tips guys, I'll try it out. Yeah a pain to redo everything but if it keeps my phone from locking up it's a plus.
    hell_on_heels likes this.
    11-18-2012 07:08 AM
  6. kristin keller's Avatar
    Yes I have been having this same issue! I have gone as far as taking the application off my phone and reinstalling it and also tried dumping the whole phone and reloading everything on it! Nothing works!!!
    09-26-2013 12:51 PM
  7. GSDer's Avatar
    Do you mean that you did a Factory data reset?
    After doing that, did you reload the GO SMS Pro app?
    Have you tried booting into Recovery mode and clearing the cache?
    It's possible that this app just doesn't "play well" with some other app on the phone.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    09-26-2013 02:06 PM
  1. Did a battery pull cause my phone was locked up.. and...
    By Raptor5150 in forum Virgin Mobile Optimus V
    Last Post: 10-09-2011, 11:59 AM
  2. New Micro SD Card Causes System to Lock Up
    By johnbre999 in forum Motorola Droid 2
    Last Post: 05-13-2011, 06:23 PM
  3. Replies: 1
    Last Post: 03-17-2011, 01:09 PM
  4. What cause my N1 to occasionally lock up or reboot?
    By Arkapigdiesel in forum Google / HTC Nexus One
    Last Post: 02-05-2011, 06:01 PM
  5. Blue Tooth Access causes phone to lock??
    By oldAGE in forum Verizon Fascinate
    Last Post: 09-15-2010, 10:17 AM
