1. jmaudi0's Avatar
    how can i change the update interval for the default lock screen weather display? mine updates very rarely (if at all) and is always different than my home screen weather widget. does it matter than I keep GPS and verizon location services turned off and only keep the google locations services turned on?
    thanks.
    11-26-2012 10:41 AM
  2. topgear66's Avatar
    Have you tried changing the weather widget refresh interval from never to 1, 3, or 6 hours? Click on the lock screen weather widget and go menu>settings>refresh interval. Hope this helps.
    11-27-2012 01:10 PM
  3. dcharleyultra's Avatar
    thanks.
    Turn on GPS.
    Swyped from my SPH-L710
    12-08-2012 12:57 PM
  4. Rassilon's Avatar
    I think you'll find this is a bug in Verizon's software. I've been searching for the solution as well, and nobody has an answer, short of replacing the default lock screen with a third-party replacement. GPS and refresh settings have nothing to do with this issue, as my refresh is 60 minutes, and all location services are enabled. A factory reset fixed it briefly (for about 3 days) before it broke again with the next OTA update.
    EDIT: I dug into my system settings a bit, and found a possible fix. Scroll to the bottom of the "Manage Apps" screen and look for disabled programs. For some unknown reason, several of my Verizon and stock apps were disabled, including the weather and news services. Turning those back on did the trick. Curiously, "Email" is still disabled, and I can't turn it back on. it also claims to be 0 bytes, which seems unlikely for a program built-in to the ROM ...
    12-15-2012 11:50 AM
  5. Atanas Penchev's Avatar
    not GPS - GPRS !!!! it will recive data momentaly , but only by gprs
    05-27-2013 01:23 PM
  6. Doug613's Avatar
    Try settings> > lockscreen> > lockscreen options>Weather. When you tap on weather, refresh rates.
    12-05-2013 03:01 AM
  1. Lock screen we as weather not updating.
    By One King in forum Sprint Galaxy S III
    Last Post: 11-18-2012, 01:58 PM
  2. Replies: 0
    Last Post: 10-23-2012, 05:03 PM
  3. Lock Screen Weather Update?
    By gyroslice in forum Samsung Galaxy Note 10.1
    Last Post: 08-29-2012, 05:41 PM
  4. HTC weather not updating
    By syrguy1969 in forum Verizon Droid Incredible
    Last Post: 05-08-2010, 10:33 PM
  5. Default Lock Screen
    By kbshowtyme in forum Samsung Moment
    Last Post: 04-19-2010, 01:53 AM
