1. AustinTech's Avatar
    Guys, my GS3 had a decent GPS lock time and decent Navigation, but sometimes I'd find the Navi drifting off and putting me on odd streets that I wasn't on, silly stuff like that. So I downloaded GPS Status, which I used on my old Thunderbolt, and since then my GPS has been even more screwy. So I downloaded GPS Fix, which helped a bit, but not much. What the heck is happening?
    Anyone have any ideas of how to fix it? I'd rather go back to the way it was prior to GPS Status than deal with the current non-sense. My phone can't even get a lock to tell me the weather. Is there any way to reset the GPS to factory settings? Help!
    12-06-2012 01:06 PM
  2. smooth4lyfe's Avatar
    Are u using the Google Navigation? Or some other app?
    funkylogik likes this.
    12-06-2012 01:28 PM
  3. AustinTech's Avatar
    Google Navi.
    Sent from my SCH-I605 using Android Central Forums
    12-06-2012 02:06 PM
  4. funkylogik's Avatar
    Try google id say and get rid of those apps.
    OOPS IGNORE THE ABOVE LOL
    U should be able to get weather where you are without GPS, just usin the carrier towers btw
    Unbranded international s3 with Official JB. Paisley, Slotland, Western Europe :beer:
    12-06-2012 04:57 PM
  5. smooth4lyfe's Avatar
    Google Navi.
    Are you rooted? I might be your area
    Try clearing the cache of the navigation app
    Settings -> Application Manager > All -> Maps
    Click Clear Cache
    12-06-2012 11:14 PM
  1. Help with GPS issue after GB update?
    By kgilbertsen in forum Sprint Epic 4G
    Last Post: 11-13-2011, 02:56 PM
  2. help with cm7.1 gps
    By ricbon in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 10-25-2011, 09:30 AM
  3. Help - Trouble with Gps in Italy
    By FribbleToe in forum Verizon Droid Charge
    Last Post: 08-31-2011, 06:06 AM
  4. Help with a GPS app?
    By nuker2guy in forum Android Apps
    Last Post: 12-23-2010, 08:20 PM
  5. Google Maps loading problem with GPS-Need help.
    By arcane#AC in forum HTC Hero
    Last Post: 12-13-2009, 05:18 PM
