1. AlexBlin2's Avatar
    I recently got a Galaxy S3, and I just put all my music on to the phone. I plugged my phone in and copped over all my music files onto the Galaxy S3. When I go to play the music on the phone I notice it sounds a little plan from what I'm use to listening to. I plugged my headphones back into my PC and noticed a huge difference, and same with my iPod, then back to Galaxy and I notice their is a huge loss in sound quality.
    The sound quality sounds more 'full' is one way to put it, it just sounds better on the PC, and iPod. Why is this happening? It must have something to do with the files being transfered over to the Galaxy are the music files compressed at all? How can I fix this please help! The EQ didn't help too much......
    - Alex
    12-13-2012 01:14 AM
  2. gwappa's Avatar
    Make sure your computer or the sync software you used to transfer the music didn't transcode it to a lower bit rate. When I first got the SGS3 I wasn't too impressed with the out of the box sound quality. I ended up rooting my device and installed the Beats Audio driver. Wow did that make a huge difference! Also you may wish to try a different music player like Poweramp Music Player.
    12-13-2012 06:50 AM
  3. WAWood8's Avatar
    If you mean the music sounds a lot better on headphones -- that is to be expected. The speakers on these phone were really designed only to be used with phone calls. They're not large enough or sophisticated enough to produce good sound quality.
    And, I second the recommendation for PowerAmp. It has equalizer settings that can seriously affect the quality of the sound you hear -- but again, you need headphones or decent speakers to hear the music in good quality.
    12-13-2012 11:59 AM
  4. AlexBlin2's Avatar
    Yeah that sounds like the issue. How do you root the device? and what does that mean? I definitively think it lowered the bit rate by quit a lot. I put my music on an micro drive just to let you know.
    12-13-2012 07:54 PM
  5. gwappa's Avatar
    Root just means allowing full access for you and apps to your phone. This can potentially be harmful if you don't use common sense, however benefits outweigh the risks for me and I get to use Beats Audio, which makes my music sound proper.
    Android rooting - Wikipedia, the free encyclopedia
    12-14-2012 03:38 AM
  1. Replies: 0
    Last Post: 11-02-2012, 08:04 AM
  2. new galaxy s3 user
    By Loose_Torch_Slider in forum New to the Forums? Introduce Yourself Here!
    Last Post: 10-13-2012, 01:09 AM
  3. New Android Tablet user needs help
    By vpharr in forum New to the Forums? Introduce Yourself Here!
    Last Post: 02-27-2012, 11:14 PM
  4. New user needs help
    By Roy Smith in forum General Help and How To
    Last Post: 11-15-2011, 01:45 PM
  5. Need help: music player stops working after 3-5min
    By Spoon in forum Motorola Droid Pro
    Last Post: 03-31-2011, 02:12 PM
