1. chopper5273's Avatar
    I installed smart keyboard and all was fine for about an hour, then the touchscreen does not work at all. I have removed the battery several times and this does nothing to fix the problem. How do I hard reset? Is there anything else I can try to get this to work without losing any of my data?
    12-21-2012 10:56 PM
  2. chopper5273's Avatar
    Anyone?
    crester likes this.
    12-21-2012 11:22 PM
  3. chopper5273's Avatar
    Several views but no responses. Can anyone help me with this phone? It's kinda of useless without the touchscreen working.
    12-22-2012 12:07 AM
  4. blade22222's Avatar
    If all else fails boot into recovery by holding volume up, home button and the power button at the same time till you see recovery booting in the top left of your screen. Use the volume rocker to select wipe data/ factory reset then press the power key to start the process. This will wipe all your data from your device. It'll be just like when you bought it. All personal data will be lost.
    Sent from my SCH-I535 using Android Central Forums
    12-22-2012 07:31 AM
  5. Scythe55's Avatar
    That ^ and if it doesn't work.....replacement.
    12-22-2012 04:12 PM
  1. My Nexus 7 will not unlock has anyone else had this problem and what should I do.
    By Peggy Brooks in forum Google Nexus 7 Tablet (2012)
    Last Post: 09-29-2013, 10:18 AM
  2. Help What Should I Do
    By datmjboi in forum General Help and How To
    Last Post: 08-03-2011, 01:33 AM
  3. Evo Screen Water Damage. What should I do?
    By tmac4life#CB in forum HTC EVO 4G
    Last Post: 08-13-2010, 03:51 PM
  4. What should I do. Help please
    By ballsout in forum HTC EVO 4G
    Last Post: 07-16-2010, 03:54 PM
  5. I have a spec of white dust under my screen, what should I do?
    By ozzman54 in forum Verizon Droid Incredible
    Last Post: 05-20-2010, 11:19 AM
