1. milenia927's Avatar
    My phone keeps recognizing that i have an update available. Every time I try to install it, it fails about half way through and reboots itself. I tried installed samsung kies in hoping it will help me install my firmware. However, while kies does recognize I have an out of date firmware, it keeps telling me that my device's firmware version is not supported to update firmware via kies. Can anyone help me with this?
    01-13-2013 07:48 PM
  2. meyerweb#CB's Avatar
    Is your device rooted?
    Check settings > About device > Status and see what Device Status (all the way at the bottom) says.
    If you're NOT rooted, and this says "modified", and you have an SD card installed, try removing it, rebooting, and then try the update without the SD card installed. No, that doesn't make sense to me either, but it seems to have worked for some people.
    If you ARE rooted, that's why the update won't finish, although I think if that were the cause it wouldn't even start.
    01-13-2013 09:29 PM
  3. milenia927's Avatar
    Sorry I am new to this. I checked my device status and it says normal. I did not root my device. I just tried removing my SD card to update the firmware but still no luck with it succeeding.
    01-13-2013 09:59 PM
  4. GSDer's Avatar
    A little more information would be helpful:
    - what version firmware do you currently have
    - what carrier are you with
    - what version does the update reference
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    01-13-2013 11:02 PM
  5. mssca's Avatar
    I had a failed firmware OTA update before. I try to do it using the computer, but it gave me a message saying that the OS is up to date. I think they delay the software push for computer based install. After a day, I was able to download it.
    So, may be a wait for a day or two and check for updates on Kies?
    01-13-2013 11:22 PM
  6. milenia927's Avatar
    My carrier is verizon.
    My current firmware is PDA:LHE/PHONE:LHE/CSC:LHE (VZW) according to samsung kies.
    The version it references to update to is JRO03L.I535VRBLK3, which includes the andriod 4.1 JB update. My current andriod version is 4.0.4.
    01-14-2013 01:07 AM
  7. Snake Hamlin's Avatar
    also keeps shutting off automatically then restarts phone continuously. Same goesfor my PRL, software's, and all my Android systems installed prioritization are disabled too. Factory reset hasn't helped.
    08-18-2016 04:49 AM
  1. Do NOT want ICS OTA Update Frusterated please HELP!
    By JayK9684 in forum Verizon HTC Rezound
    Last Post: 08-16-2012, 11:12 AM
  2. System Update Unsuccessful - Please Help
    By Richgecm in forum General Help and How To
    Last Post: 05-12-2012, 10:04 AM
  3. .621 Update Issues, Please Help!!!
    By Thehomez in forum Motorola Droid X
    Last Post: 04-16-2012, 05:21 PM
  4. New Firmware Update error. Need help!
    By Maurifuentes in forum Misc. Android Phones
    Last Post: 04-16-2012, 10:20 AM
  5. n00b updating milestone...please help.
    By jessman1988 in forum Motorola Droid
    Last Post: 05-18-2011, 08:00 PM
