1. neil154's Avatar
    My wife and I each have an S3 and we can connect by wifi direct. I also have a Dell Desktop which has wifi direct (Intel card 6230) which has wifi direct.
    Our S3s can see the desktop PC but they will not connect. When I tap to connect it searches for a long time and then eventually gives me a message that connection failed.
    Anyone have ideas on the problem?
    02-09-2013 10:12 AM
  2. GSDer's Avatar
    What happens if you try to initiate the connection from the PC?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    02-09-2013 10:18 AM
  3. neil154's Avatar
    Nothing different, the connect fails. The PC does see the S3 and the S3 does see the PC, so discovery is not the problem.
    02-09-2013 11:08 AM
  4. AxlMyk's Avatar
    Do you have sharing turned on with the PC?
    02-09-2013 08:35 PM
  5. neil154's Avatar
    I have some sharing on but I do not have the root folder shared because that would leave my system very vulnerable. Do you really think I have to set the root folder (which would mean the entire hard drive) to shared?
    02-09-2013 08:53 PM
  6. Suntan's Avatar
    I've tried wifi direct with my N7 and it has been very sketchy at best. I could only get them to connect every once in a while and they would drop each other frequently. It was only once in 20 twenty that I could actually get them to transfer anything.
    You can try sharing your whole drive for a little bit, just to try it, but don't be surprised if it still doesn't work.
    -Suntan
    02-10-2013 09:06 AM
  7. neil154's Avatar
    \Shari
    -Suntan
    Sharing did not help and I contacted Intel and of course they blamed it on my Norton Internet Security program so I disabled it but still o connection and no solution
    02-25-2013 01:44 PM
  1. Wifi direct with Mac/USB transfer
    By krusej23 in forum Verizon Galaxy S III
    Last Post: 07-15-2012, 12:18 PM
  2. Wifi-Direct device name
    By nightwing1115 in forum HTC EVO 4G LTE
    Last Post: 06-25-2012, 06:23 AM
  3. Wifi Direct Access Point/File Manager
    By Revolutionary in forum Android App Inventor
    Last Post: 01-18-2012, 10:18 AM
  4. Any body know what "wifi direct" is?
    By tlincoln in forum Verizon Galaxy Nexus
    Last Post: 12-21-2011, 12:13 AM
  5. Replies: 1
    Last Post: 07-06-2011, 04:08 AM
