1. weesy's Avatar
    does anyone know of a place or of how to do a color conversion on our phone? I currently have a pebble blue model and would like to either make it white or black. obviously without the hassle of having to buy an entirely new phone. does any one know how or where?
    02-14-2013 12:38 PM
  2. crester's Avatar
    I've seen vinyl kits for the phone.
    weesy likes this.
    02-14-2013 01:22 PM
  3. nyry's Avatar
    I believe the front panel and the screen are one part, so it's going to cost you alot
    Sent from my SCH-I535 using Android Central Forums
    02-14-2013 01:32 PM
  4. meyerweb#CB's Avatar
    There are a lot of aftermarket backs available, in all sorts of colors (search amazon, ebay, and google), but I think the only easy way to change the front is with a vinyl kit, as crester suggested.
    crester and weesy like this.
    02-14-2013 02:41 PM
  5. weesy's Avatar
    thanks i'm going to look into that. seems like my best bet
    02-21-2013 01:58 PM
  1. Is it possible to edit the color scheme for Dolphin HD?
    By Ravaloft in forum Verizon HTC Rezound
    Last Post: 04-07-2012, 05:34 AM
  2. Code Decyphering - Using Braille & Possibly the colors
    By crazy_skier in forum The Android Central Lounge
    Last Post: 02-21-2012, 01:57 PM
  3. is it possible to overclock nook color running cm7
    By lions80 in forum Barnes & Noble Nook Color
    Last Post: 04-13-2011, 07:29 PM
  4. Nook Color software possible on EVO?
    By PreGk in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 12-04-2010, 11:26 PM
  5. Hanging up after a conversation...
    By Daveydave#CB in forum HTC Hero
    Last Post: 10-19-2009, 07:25 PM
