Hi guys,
So far I have used 3 chargers. A Verizon green 10ft long charger, the charger for my Nexus 7, and a Verizon car charger.
Basically when I plug any of these chargers in it will show it is charging for a split second, then it'll go away. So in order for it to charge, I have to push the charger in really hard, push it down, or bend it to the right. If I bend it to the right, when I let go, it stops charging. Sometimes I can get it at the right angle to keep it there, but I come back later and see that it isn't charging. Also if I push it in really hard, bending it to the right stops charging it.
The Verizon car charger has been the best for me even though it gives me problems, but I use my nexus 7 charger for it most of the time.
This is super annoying, how it's real hard to get it to start charging and even harder to keep it. None of the pins on my chargers look crooked, nor inside my phone. I don't know if there is a fix for this, I might just take it to Verizon.
Anyone with the same problem or know of a fix out there? Thanks!
