1. htrannn's Avatar
    When I got my phone there was a mix up where I only received a 3G (HSPA+) sim card and everything was fine. I would come home from school with a good 40-50% battery left in most cases. I swapped to an LTE sim after finding out I could get faster data and since then my battery life has been terrible. I come home with anywhere between 15-35%, never more. Is there a fix for this?
    02-18-2013 06:10 PM
  2. crester's Avatar
    Turn off LTE...
    02-18-2013 06:58 PM
  3. htrannn's Avatar
    How though? I've never seen an option to turn off LTE, just data ..
    02-18-2013 07:03 PM
  4. Almeuit's Avatar
    What carrier are you on?
    Sent from my Sprint S3 using AC forums.
    02-18-2013 07:30 PM
  5. htrannn's Avatar
    Virgin Mobile in Canada, so it's the same as AT&T's model.
    02-18-2013 07:35 PM
  6. Almeuit's Avatar
    Check this out and see if it helps.
    http://forums.androidcentral.com/t-g...disable-t.html
    crester likes this.
    02-18-2013 07:56 PM
  7. crester's Avatar
    Actually I'm Canadian and my phone's settings look different from that... you don't need to add APN's or anything. Here's what you do...
    Goto settings... more settings... mobile networks... network mode...
    then choose the option that's one step below LTE. On my phone it says "GSM/HSPA (auto connect)"
    That way you won't use LTE... you will be on HSPA and your battery will last longer again.
    02-18-2013 08:34 PM
  8. htrannn's Avatar
    That's very helpful thank you. If you don't mind me asking though, are you rooted and what exactly did you do? I've been looking up checks on what to do to root a Canadian S3 and AT&T files would be enough.
    02-18-2013 10:07 PM
  1. GAH! Battery Life Sucks! How to close background apps?
    By android acolyte in forum Samsung Galaxy S II Skyrocket
    Last Post: 01-07-2012, 12:29 PM
  2. Who's battery life sucks after 5.5.893 OTA?
    By jpvybes in forum Droid Bionic
    Last Post: 01-05-2012, 10:23 PM
  3. Battery Life sucks!
    By 916x10 in forum Other Sony Android Phones
    Last Post: 08-29-2011, 09:47 AM
  4. DL30 battery life sucking?
    By adellc3 in forum Verizon Fascinate
    Last Post: 02-15-2011, 03:29 PM
  5. Help, my battery life sucks!
    By lolreconlol in forum Verizon Fascinate
    Last Post: 11-02-2010, 10:55 AM
