1. V J's Avatar
    I pretty much love my 4G Galaxy S3. Aside from a couple of issues here and there it's been great so far for my first Android device.
    My problem is with Viber messenger. I use Samsungs "Blocking Mode" feature on a schedule. For those unfamiliar it's basically like the Do Not Disturb feature on iphone wherein all notifications and alerts are silenced except for people you allow on your allow list. This works extremely well in keeping my phone quiet at night.
    My problem is Viber seems to be "immune" to blocking mode. No matter what I do I can't seem to stop the alerts going off even when Blocking Mode is scheduled to be on. All the other apps get silenced except for this one. I've tried looking online and it doesn't seem to be a widespread issue. I've tried uninstalling and reinstalling to no avail. Has anyone else experienced this?? Any help would be appreciated. I don't wanna let it go because I use it to keep in contact with some friends in another country and this saves us a lot of money for our communication.
    02-19-2013 08:26 AM
  2. Zenobia Bez's Avatar
    I have the same issue and can't seem to find help any where
    08-12-2013 08:08 AM
  3. GSDer's Avatar
    Have you checked the Viber website http://www.viber.com
    Or tried sending them email info@viber.com
    You could try a 3rd party solution, like:
    https://play.google.com/store/apps/d...droid.sleeping
    OR
    https://play.google.com/store/apps/d...?id=Orion.Soft
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-12-2013 02:28 PM
  4. realisticgirl's Avatar
    I have the same issue. There is no solution. Hopefully on the next update viber will resolve the issue.
    08-12-2013 02:33 PM
  5. GSDer's Avatar
    As in, you've tried several 3rd party sound/notification management apps and none of them made any difference? It would be useful if you provided a list of the ones you've tried so that everyone would know which ones to skip.
    08-12-2013 03:51 PM
  1. Need a little help/confirmation PLEASE.
    By stopthebus in forum Verizon Droid Incredible
    Last Post: 09-03-2010, 07:38 PM
  2. Droid X tomorrow! need a little help
    By 240sxsr20 in forum Motorola Droid X
    Last Post: 07-14-2010, 10:53 AM
  3. need a little help
    By willistheyounger in forum The Android Central Lounge
    Last Post: 06-17-2010, 11:55 PM
  4. need a little help from the themers out there
    By wtphoto in forum HTC Hero
    Last Post: 02-11-2010, 09:05 PM
  5. Does anyone use Footprints?
    By zeravla531 in forum HTC Hero
    Last Post: 01-06-2010, 08:59 PM
