1. Almeuit's Avatar
    Okay I am a total newbie when it comes to this... In all the time I've had android I haven't really messed with the lock screen but I have seen some people's where they have a nice little weather widget (I think it's a widget) along with the time and date. How would I go about doing this? I am running stock (recently just went back to stock) and I used nova Launcher (if that even matters).
    Thanks in advance .
    Sent from my Sprint S3 using AC forums.
    02-21-2013 06:19 PM
  2. weriov's Avatar
    If you pop into Settings | Lock Screen | Lock Screen Options, you'll see an option that says "Weather." Just set it to On and tap on it to set the (very minimal) options, and you should be all set. (Just be warned: the weather won't display with certain types of security enabled.)
    02-21-2013 07:46 PM
  1. default lock screen weather not updating
    By jmaudi0 in forum Samsung Galaxy S3
    Last Post: 12-05-2013, 02:01 AM
  2. Lock Screen Weather Update?
    By gyroslice in forum Samsung Galaxy Note 10.1
    Last Post: 08-29-2012, 04:41 PM
  3. Lock Screen Weather as a Widget?
    By gfreakinman in forum Samsung Galaxy S3
    Last Post: 07-24-2012, 08:38 PM
  4. Lock screen weather
    By NHBass39 in forum Verizon HTC Rezound
    Last Post: 03-09-2012, 07:45 AM
  5. Weather Lock Screen & 100+ Temperatures
    By SCSnare in forum HTC EVO 3D
    Last Post: 06-27-2011, 11:09 PM
