1. Nishesh's Avatar
    The default home screen weather widget was working fine from the last 2 months. However, it does not refresh now even if I enable auto refresh or disable auto refresh and press the refresh icon manually. It does not work in either of the cases. Do I need to reinstall this widget?
    03-07-2013 05:20 AM
  2. GSDer's Avatar
    If you remove the widget and add it back that may fix the problem.
    You can also open the app and check the settings - perhaps the update interval has been changed?
    Finally, did your phone just recently receive an OTA? If so, that could be the root of your problem.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    03-07-2013 09:05 AM
  3. thingolbr's Avatar
    I have the same problem. In my case it only work with Wi-Fi. When only mobile data is available, it updates my city name but keeps saying "No weather data available". If I enable wireless again, it updates the weather data. Then, if I try to manually update the weather info using mobile data it erases the information and says the same "No weather data available" message.
    03-08-2013 07:00 AM
  1. GS3 Home Screen Weather Widget Lag
    By Joshua Granger in forum Samsung Galaxy S3
    Last Post: 12-28-2012, 02:17 AM
  2. Home Screen Weather widget
    By thomasr1950 in forum Verizon Galaxy S III
    Last Post: 10-16-2012, 10:41 PM
  3. Cal widget does not update.
    By rdmodlin in forum Motorola Droid X
    Last Post: 12-09-2010, 10:11 AM
  4. What home screen apps/widgets do you have?
    By donald.aleshire in forum HTC EVO 4G
    Last Post: 06-07-2010, 06:00 PM
  5. MT3G home screen and widgets
    By dharma89 in forum T-Mobile myTouch 3G
    Last Post: 02-26-2010, 09:34 PM
