03-23-2013 10:08 PM
32 12
tools
  1. hansam's Avatar
    I figured it out. thanks. I removed the microsd card and battery life is way much better now. I just don't know why the mmc did that
    03-21-2013 12:05 PM
  2. meyerweb#CB's Avatar
    Let us know what happens if you put it back in. If the drain reoccurs, look at the battery app and see if Media server is using a lot of battery. If the answer is yes (and I bet it will be), then you probably have corrupt media files on your SD card. Reformatting the card should solve it, if that's the problem.
    03-21-2013 12:24 PM
  3. hansam's Avatar
    media server is now on the bottom of the list only taking up 2%.. screen however is now at 68% and my brightness is always on the dimmest.. batter graph still shows the phone is awake the whole time
    03-22-2013 05:54 AM
  4. meyerweb#CB's Avatar
    Post some screen shots.....
    Sent from my Sprint Galaxy S3. Please forgive any typos or auto-correct errors.
    03-22-2013 08:56 AM
  5. hansam's Avatar
    Here they are they changed since i last checked i did not bother putting back the mmc as i think there are corrupted files there
    Attached Thumbnails what sucking my battery??-screenshot_2013-03-23-00-51-53.png   what sucking my battery??-screenshot_2013-03-23-00-51-29.png   what sucking my battery??-screenshot_2013-03-23-00-51-45.png
    03-22-2013 11:52 AM
  6. meyerweb#CB's Avatar
    Interesting. 11+ hours with 2 1/2 hours screen on time, and 44% battery left, and not on WiFi, is actually darn good. That would translate into something close to 20 hours on a charge. I don't think you can expect a lot better than that. Right now I'm looking at 15 hours with 34% left, WiFi for most of that time, and about 3 hours of screen on time.
    But something is keeping your phone awake. Whatever it is isn't using a lot of battery.I think you're going to have to install one or more of the programs suggested earlier in this thread to track it down.
    geekymcfly likes this.
    03-22-2013 08:39 PM
  7. KreepyKen's Avatar
    Almost down less than 50, yes coming from full charge.. almost full after 2 hours and it is without using the phone after disconnecting charger after 5 mins there goes 1% and after 5 mins another 1%
    THIS IS THE PLUMMET! Don't do a factory reset...it won't help.
    Evidence #1: See how it cruises along just fine and then at one point the angle steepens (right over the "er" in battery in the first shot)?
    Evidence #2: Android System is too high on that list.
    Now I have to ask, were you in an LTE area at all during the day? Looks like the plummet kicked in around 10:30 PM. Were you in an LTE area at that point? And did you have wifi on? (from the third picture, it looks like wifi was never connected, but was it turned on?).
    Typically, the plummet is a product of LTE + Wifi with the phone unable to resolve which network it should use and freaking out. This happens to me at work, which is in an LTE area and I connect to wifi every day. I've tried a lot of things, but the only thing that works is to restart my phone when I get to work. Since I've been doing this, the plummet stays away. If I don't reboot the phone as I'm walking into work, the plummet will occur that day.
    03-23-2013 10:08 PM
32 12
  1. Why is Gallery sucking my battery dry?
    By boristhebad in forum Samsung Galaxy S3
    Last Post: 01-21-2013, 04:29 PM
  2. Replies: 14
    Last Post: 01-09-2013, 06:45 PM
  3. Whats eating my battery!? Widgets? Apps? Android system?
    By tony477g in forum Verizon Galaxy S III
    Last Post: 10-01-2012, 08:08 PM
  4. whats killing my battery???
    By michollock in forum Verizon Fascinate
    Last Post: 01-23-2011, 02:42 PM
  5. My battery still sucks.
    By jmjccwatson in forum HTC EVO 4G
    Last Post: 07-03-2010, 12:54 PM
