1. sad_old_man's Avatar
    My wife has had her SIII for a while now and everything appears to work correctly. The exception to this is that two contacts that she has on her phone are saying that they cannot contact her by text. She can text both of them perfectly but when they send her a text it never arrives for some strange reason. I have checked her phone settings and they seem ok. I have deleted both contacts and re entered them and still nothing works. Anyone got any suggestions?
    03-26-2013 11:39 AM
  2. meyerweb#CB's Avatar
    Did your wife previously have an iPhone, and are the people who can't text her using iPhones? If so, see these threads:
    http://forums.androidcentral.com/sam...ng-me-off.html
    http://forums.androidcentral.com/spr...galaxy-s3.html
    http://forums.androidcentral.com/sam...i-message.html
    03-26-2013 12:56 PM
  3. sad_old_man's Avatar
    Thanks for the reply. My wife has never owned an iphone, it's a long story but they are not allowed in my house. As far as I'm aware none of the people have had iPhone. I will read the threads anyway and any suggestions are welcome because you do understand what wife's are like when they get on your case!
    03-27-2013 02:29 PM
  4. meyerweb#CB's Avatar
    If iPhones aren't involved, those threads won't help.
    Does she get texts from other people? Can those two people get texts from her? If those two people text you, do you get them?
    The stock messaging app has the option of marking numbers as spam. It seems unlikely, but in the messaging app tap menu, then Spam, and see if there are any messages there. If so, go into settings (in the messaging app), scroll all the way down, and check the Spam settings options. There's also a block unknown senders option, and if the numbers in her directory don't match the sending numbers (area codes in the directory, but not on the incoming message, or vice versa?) they could be getting blocked.
    sad_old_man likes this.
    03-27-2013 02:45 PM
  5. sad_old_man's Avatar
    Your replies are most welcome and yes I can see what your saying. No other contacts are involved and texts between my wife and all other contacts work as they should. My wife can also ring the two contacts concerned and text them with no problem. They can ring her but when they text her, it just doesn't arrive unless of course you are correct in the fact that they are in fact being received but are directed into the spam folder. I though she would still receive a notification though but it's a good place to start. I will check this out later when I get home. Thank you kind sir.
    03-30-2013 08:28 AM
  6. sad_old_man's Avatar
    Exactly what you said. For some reason all the missing texts were in the spam folder. Selected restore them and unblock the two numbers and violla! Perfection restored. Thank you for your help!
    04-01-2013 12:40 PM
  7. meyerweb#CB's Avatar
    Glad to be of service!
    04-01-2013 01:51 PM
  1. Problems with text messages
    By Cethern in forum Sprint Epic 4G
    Last Post: 10-06-2010, 05:59 AM
  2. Problem with Texting :(
    By UltimateBB9700User in forum Motorola Charm
    Last Post: 09-18-2010, 05:14 PM
  3. Small problem with texting.
    By ABad Santa in forum Verizon Droid Incredible
    Last Post: 09-15-2010, 05:27 PM
  4. Strange problem with Google contacts
    By breugel in forum Verizon Droid Incredible
    Last Post: 08-21-2010, 10:38 PM
  5. Problem with Text Messages
    By JayMSY in forum Motorola Droid X
    Last Post: 08-14-2010, 04:51 PM
