1. panthers711's Avatar
    I got this phone when it came out and put a 32gb class 4 sandisk sd card in it. All i stored was my music and it worked perfectly until about a couple of days ago where it completely stopped recognizing my card. Any suggestions?
    04-06-2013 03:29 AM
  2. blade22222's Avatar
    Try reformatting it in you computer and if that don't work get a new card. It's a common problem, just look through this forum.
    Sent from my SCH-I535 using Android Central Forums
    04-06-2013 09:15 AM
  3. bassmig's Avatar
    If it can't be read by your PC you may want to check with SanDisk on a possible warranty replacement. Most card carry a 3-5 year warranty so a 32GB card should probably still be under warranty. There are multiple threads in here about this issue.
    04-06-2013 10:26 AM
  4. Golfdriver97's Avatar
    Contact SanDisk right away, and keep the card. Sandisk announced recently of a recall on micro SD cards. Don't know all the details, but it did pertain to smartphones shorting out cards.
    04-06-2013 11:44 PM
  5. SpiralBorg's Avatar
    They did state that they had manufactured an small percent of faulty SD cards.
    Sent from my MZ604 using Android Central Forums
    04-06-2013 11:51 PM
  6. AxlMyk's Avatar
    Did you read any of the other threads about this? No? There must be 10 of them.
    Call SanDisk, and get a new one.
    --Tapatalk on SGS3.
    04-07-2013 08:25 AM
  7. sp0tted's Avatar
    SanDisk replaced mine last week. The process was painless.
    Sent from my Nexus 7 using Tapatalk HD
    04-07-2013 08:29 AM
  1. Ger my space back on sd card?
    By illinoissparks18 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 02-21-2012, 11:12 PM
  2. getting to my files on the SD Card
    By flowergirl in forum General Help and How To
    Last Post: 11-29-2011, 08:38 PM
  3. after hard reset - can I get my apps back from SD card?
    By Hawaii Built in forum General Help and How To
    Last Post: 08-02-2011, 06:30 AM
  4. Replies: 21
    Last Post: 02-28-2011, 05:44 PM
  5. Replies: 2
    Last Post: 12-29-2010, 01:02 AM
