1. Febin Lawrence's Avatar
    Please Help Me...
    I bought a sIII recently. And the problem is, whenever i launch an application, it first starts..then goes blank[Black screen]..then it comes again..after few seconds it goes blank and thereafter it just repeats...
    It's really Frustrating.!!
    I even closed all the running apps, made time-out to 2 minutes, etc...
    Hoping to get a reply soon....
    Thank You
    04-14-2013 03:11 PM
  2. Golfdriver97's Avatar
    Please Help Me...
    I had bought the phone recently.And the problem is, whenever i launch an application, it first starts..then goes blank[Black screen]..then it comes again..after few seconds it again goes blank and it repeats..
    It is really Frustrating..
    Hoping to get a reply...
    Have you tried rebooting into recovery and wiping cache?
    04-14-2013 03:20 PM
  3. Febin Lawrence's Avatar
    no..
    Can you please explain..
    I'm a first time user..
    04-14-2013 03:21 PM
  4. smooth4lyfe's Avatar
    What is ur timeout time in settings on?
    Try changing it to 1 minute or longer, I think default is 30 seconds
    04-14-2013 03:24 PM
  5. Febin Lawrence's Avatar
    i changed it to 2 minutes..but no luck..:/
    04-14-2013 03:25 PM
  6. Febin Lawrence's Avatar
    no..
    04-14-2013 03:26 PM
  7. smooth4lyfe's Avatar
    Settings -> Display -> Screen Timeout
    There is no 2 minutes lol, it gots from 1 minute to 3 minute....try turning it off and see
    04-14-2013 03:27 PM
  8. Febin Lawrence's Avatar
    tried it...fail
    This problem started like 2 months b4..
    i thought it was nothing serious.
    then it just frustrated me...
    04-14-2013 03:29 PM
  9. problemshredder's Avatar
    1. it may not be the screen timeout setting. have you tried using the app while the phone is charging ? when charging, the screen display brightness may be set to full 100%. then, go to : setting - system - developer options. enable developer options first, then check "stay awake". this will prevent phone from timing out as long as it is connected to the charger.
    2. if after this the screen still goes black, then the problem is not related to screen timeout setting but the app itself not working properly. try opening other applications and see if the blackout still happens.
    3. if somehow this happens to all applications, then the error seems to be with the phone settings. the quickest solution but not the best is, doing Factory Reset and restore everything to original state.
    4. last resort when the problem insists after factory reset, the phone hardware is faulty, but fortunately the warranty is still in effect. just bring it to the nearest samsung point.
    PoorPigg likes this.
    04-14-2013 06:16 PM
  10. Golfdriver97's Avatar
    no..
    No sweat. Power down. Reboot by pressing power home and volume up keys at the same time and release when you see the Samsung logo. (I find it easiest to hit volume and home first, then power). You will then reboot into recovery mode. Scroll down using the volume keys and highlight wipe cache partition. Touch power to select (if that doesn't work try Home key). Next it should wipe then bring you to the top of the menu, highlighting reboot and hit power/home.
    04-14-2013 10:09 PM
  11. Golfdriver97's Avatar
    Factory resets are suggested way too much. Wiping the cache does the same thing, is faster, and preserves your data and settings. If the problem still exists, then it is a problem with the app, or a hardware problem with the phone. Now, a factory reset may help where wiping cache does not, but that is very rare. Part of the factory reset process IS wiping cache. You could also try settings in the app itself, but in this case it seems unlikely, due to the screen blacking out frequently.
    04-14-2013 10:16 PM
  12. Febin Lawrence's Avatar
    It happens to all my applications..even my camera..!!
    04-15-2013 12:12 AM
  13. Febin Lawrence's Avatar
    The thing is it happens to all my apps, not just a particular app..
    04-15-2013 12:14 AM
  14. meyerweb#CB's Avatar
    Did you try the troubleshooting steps 1 and 2 in Post #9? If not, go do them and tell us what happens.
    Did you try clearing cache as described in post #10? If not, do that and tell us what happens.
    Until then, there's not much more we can suggest.
    04-15-2013 09:11 AM
  15. rexxman's Avatar
    Thanks for this tip ProblemShredder! I was trying to figure out how to keep my screen on when plugged into 12 VDC and using Navigation. I do wonder why they just don't put that setting under display? But no matter, thanks to you, I'm again a happy camper.
    06-02-2013 03:51 PM
  1. Samsung Galaxy SIII vs. HTC One X vs. Samsung Galaxy SII Skyrocke
    By pennylilithwise in forum AT&T Galaxy S III
    Last Post: 06-18-2012, 09:15 PM
  2. Are These the First Photos of the Samsung Galaxy SIII?
    By deesugar in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 04-19-2012, 05:02 AM
  3. samsung galaxy s 4g internet problems
    By vasquezcassie in forum T-Mobile Galaxy S 4G
    Last Post: 06-26-2011, 08:40 PM
  4. [help] After Samsung Galaxy S Screen its blank. trying to get back to stock
    By cainstuh in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 03-10-2011, 01:04 PM
  5. Samsung Galaxy S Domain email Problem
    By Bayside Jule in forum General News & Discussion
    Last Post: 10-14-2010, 01:28 AM
