1. RedorBluePill's Avatar
    Hi. Has anyone experienced loss of sound in their S3? This happened to me three times, every time over night. The alarm would turn on in the morning but without sound (yes I overslept). When I realized there was no sound I tried playing any music (youtube, music files) and calling myself from another phone, and there would be no sound, just vibration. I checked every time and I didn't "Turn off all sounds", the sound was on in the notification bar too. Youtube video would not play at all, not just audio.
    Any ideas? Thanks. I'm on 4.1.2.
    04-17-2013 11:27 AM
  2. meyerweb#CB's Avatar
    Do you have any type of battery saver, task manager, or profile app on your phone? Have you enabled blocking mode? Are you using the alarm that's standard on the phone, or a third party application?
    04-17-2013 11:31 AM
  3. RedorBluePill's Avatar
    Hi, tnx for reply. No battery saver, no task manager, no profile app, blocking mode is off, using the phone's alarm.
    Also, after I restart the phone everything turns back to normal.
    04-17-2013 12:11 PM
  4. meyerweb#CB's Avatar
    Very strange. I don't have any more ideas at the moment, but if something comes to mind I'll come back here and let you know. Good luck.
    04-17-2013 01:24 PM
  5. bassmig's Avatar
    Reboot, battery pull and if that doesn't work factory reset. If issue persists bring it back for a new one...
    Most importantly set a back up alarm in case!
    04-17-2013 05:59 PM
  1. lovin meh optimus - over night?
    By Dave Begue in forum Virgin Mobile Optimus V
    Last Post: 09-20-2011, 10:08 AM
  2. Losing connectivity over bluetooth speaker?
    By wcassell in forum T-Mobile HTC Sensation
    Last Post: 08-17-2011, 07:26 PM
  3. Battery Drains Over Night?
    By brettnussb in forum T-Mobile Nexus S
    Last Post: 05-17-2011, 10:18 PM
  4. Charging over night?
    By kaufmansm in forum Verizon HTC Thunderbolt
    Last Post: 03-18-2011, 04:26 PM
  5. X makes weird sounds at night
    By Arelunde in forum Motorola Droid X
    Last Post: 08-30-2010, 03:36 PM
