1. woska89's Avatar
    I've had this problem before and factory reseted my phone. Now few month later, im having the same issue.
    System_server and com.android is at the top of list. Does anyone know what this is and how I can fix it without rooting my phone?
    Sent from my SGH-T999 using Android Central Forums
    Attached Thumbnails Samsung Galaxy S3 Android System drainage-uploadfromtaptalk1366743372306.jpg   Samsung Galaxy S3 Android System drainage-uploadfromtaptalk1366743499983.jpg
    04-23-2013 02:36 PM
  2. Golfdriver97's Avatar
    OK....as of the pic, you have gone nearly 7 hours and have used only 24% of your battery. The battery usage graphs is just showing of the 24% used, most of it was used by the Android system. The next most is the screen. I take it you don't turn the phone on much. If that is true, the system being idle is going to drain the battery. It will adjust if you use your phone for something. Play a game for about 20 minutes and the resource list will change.
    04-23-2013 02:53 PM
  3. woska89's Avatar
    Is it normal though for the Android System to reach up to 50% when the phone is idle?
    because i believe i could get more battery life out of my phone if the Android System wasnt so high. (normally get around 18 - 25 hrs.)
    04-23-2013 02:59 PM
  4. Golfdriver97's Avatar
    Your battery life is already outstanding. As of this writing, I have gone 3 hours, 13 minutes and 17 seconds on battery and I am down to 77%. And I am a light user of my device. There are some users who go though the entire battery twice in the course of a day.
    The system is always running, so therefore, always taking power. Since you leave the phone alone so much, the battery summary is saying that of the drains that the system sees most of it is from the Android system. So to answer your question, 50% of the charge to the System would see about right.
    04-23-2013 03:14 PM
  5. woska89's Avatar
    thnxs. since i had a problem with my phone before with Android System draining my battery to 6 hrs max without using it, i thought it was doing the same thing in a slower pace this time.
    04-23-2013 03:20 PM
  1. Samsung Galaxy s3 android system drainage
    By woska89 in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 04-23-2013, 02:00 PM
  2. Best Anti-Virus app for Samsung Galaxy S3 (or other Android phones)?
    By ipwn3r456 in forum Android Security Apps, Tips & Strategies
    Last Post: 03-29-2013, 08:47 PM
  3. Samsung Galaxy S3 Android System!!!
    Last Post: 03-15-2013, 08:53 PM
  4. Replies: 3
    Last Post: 01-31-2013, 10:11 AM
  5. Root your Samsung Galaxy S3 On Android 4.1.2 Jelly Bean Official Firmware
    By jakson0100 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-07-2013, 09:05 PM
