1. Kairos1189's Avatar
    Does anyone know how to do a 3G speed hack to make data faster or how to uncap data when throttled. I have the propmoder app on but wanted to if there is another way to make 3G faster or to unthrottle it.
    Sent from my SCH-R530C using Tapatalk 2
    04-24-2013 12:36 AM
  2. Soundtrack to Chaos's Avatar
    There's one on XDA, don't have the link atm, but it was in the apps and games section
    04-24-2013 01:31 AM
  3. GTWalling's Avatar
    You may be able to get faster 3G speeds, but as far as uncap data, can not be done unless you pay for true unlimited.
    Christopher Draus likes this.
    04-24-2013 06:17 PM
  4. meyerweb#CB's Avatar
    uncapped data = WiFi. Or Sprint. No other way.
    GTWalling likes this.
    04-24-2013 06:20 PM
  5. Soundtrack to Chaos's Avatar
    Yea, u can't ubcap data, but you can make it go faster
    04-25-2013 06:20 AM
  6. Kairos1189's Avatar
    How can I make my 3g faster I'm currently rooted running stock rom
    05-04-2013 09:11 AM
  7. Soundtrack to Chaos's Avatar
    Google search is your friend. Not to be a dooche, but I'm pretty sure if you put in 3g speed hack xda or how to boost 3g speeds xda, u will find a thread telling u how
    05-04-2013 09:16 PM
  8. GTWalling's Avatar
    If you have been throttled by your provider there will be no way to speed it up as they have cut your 3G/4G signal and only allowing 2G/Edge to the phone. Learn to use Wi-Fi when available.
    05-05-2013 01:26 PM
  1. Post your 4G/3G speed!
    By Beezzy in forum Sprint
    Last Post: 07-01-2010, 04:25 AM
  2. Post your 4G/3G speed!
    By BazzBro in forum HTC EVO 4G
    Last Post: 06-28-2010, 11:18 AM
  3. 3g speeds down in certain areas
    By jrobinson in forum Sprint
    Last Post: 06-27-2010, 04:26 PM
  4. Droid w/Froyo Verizon 3g Speed Tests
    By b1gt78 in forum Motorola Droid
    Last Post: 06-21-2010, 03:48 AM
  5. 3g Speed drop
    By mikea3000 in forum Google / HTC Nexus One
    Last Post: 06-06-2010, 02:26 PM
