1. Kairos1189's Avatar
    Does anybody know of a good case for this? like a pouch of some kind. I was looking at XX-Large Heavy Duty Solid Black Rugged holster Pouch,RuggedQX but I don't know if it would fit the phone is pretty thick with the ZeroLemon 7000mAh.
    Sent from my SCH-R530C using Tapatalk 2
    04-25-2013 11:22 AM
  2. Soundtrack to Chaos's Avatar
    You really don't need one, I've been using the case that comes with it and it's perfectly fine
    04-25-2013 01:54 PM
  3. Kairos1189's Avatar
    Does the case fit nice and snug. And have you dropped it, what was the result like did the case come off or did it protect the phone pretty good. The only reason why I want the pouch is because I'm always traveling at work and would like to have it on my waist then rather in my pocket.
    04-25-2013 02:01 PM
  4. geekymcfly's Avatar
    The case is snug and it feels great while on hand. I dropped mine and I haven't had a issue with it. I don't think the case fits in any other case to tell you the truth.
    TMO GS3 * NEXUS 7
    04-27-2013 11:28 PM
  5. Soundtrack to Chaos's Avatar
    TMO GS3 * NEXUS 7
    They are supposed to come out with a rugged case this summer for it
    04-28-2013 02:36 AM
  6. Kairos1189's Avatar
    Do you know the manufacturer or where can it be bought at?
    04-28-2013 05:15 PM
  7. GSDer's Avatar
    http://www.amazon.com/gp/aw/d/B00A53...cUvbUpU2741421
    Unfortunately the item has been so popular (I blame Soundtrack to Chaos) that it's currently unavailable through Amazon.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    geekymcfly likes this.
    04-29-2013 01:50 AM
  8. Soundtrack to Chaos's Avatar
    http://www.amazon.com/gp/aw/d/B00A53...cUvbUpU2741672
    Lol, I guess I played some minor role in the battery's popularity, at least on AC
    04-29-2013 06:23 AM
  9. geekymcfly's Avatar
    You deserve more credit than that.
    Btw zerolemon is supposed to be making it so it may or may not be available soon through amazon
    TMO GS3 * NEXUS 7
    04-29-2013 02:09 PM
  10. Soundtrack to Chaos's Avatar
    TMO GS3 * NEXUS 7
    Thanks, I think they will make the case available through amazon, but there is no guarantee. I'm more concerned about the price and design of the case. And am not looking to pay 50$ for it, like I did with the otterbox defender series
    04-29-2013 05:31 PM
  11. geekymcfly's Avatar
    You think they would go that high? I don't even use my defender. What a waste of money? I wonder how it'll look
    04-29-2013 05:47 PM
  12. Soundtrack to Chaos's Avatar
    I actually have 2 defenders, one I got as a free replacement, and then other, then rubber is stretched out
    I think they atleast go 25-30$ on the case, maybe a lil more depending on the sales, because if u follow how they priced the battery, it came out cheap, the the price started rising
    04-29-2013 06:43 PM
  13. geekymcfly's Avatar
    True
    04-29-2013 07:31 PM
  14. Soundtrack to Chaos's Avatar
    True
    Case well definitely be over 25$, just checked and u can get the blue tpu case for 12, so the rugged cases definitely are starting at about 25
    My name is Soundtrack to Chaos, and I have a fetish for external chargers, big batteries, power outlets and extension cords... I need help
    05-01-2013 10:35 PM
  15. ElGugo12's Avatar
    I use a reiko pouch intended for a samsung note.
    FlawedLegacy likes this.
    05-19-2013 01:27 PM
  16. FlawedLegacy's Avatar
    W/ extended battery fits in this case? I've been DYING to get a belt pouch to fit w/ my extended battery
    05-23-2013 10:43 AM
  17. dthomaz's Avatar
    You might try the following. I have a "Otterbox Defender" case & holster which I wanted to use with the "ZeroLemon " battery. Naturally the two won't fit in stock form so a little customization had to be implemented. If you cut-out a section in the rear of Otterbox hard case, it will mate with the front of the case. This way you don't loose any of the screen protection and the two halfs now fit properly into the neophrene softcase. The fit is a little tight but I haven't had issues using the case with the holster. I'll admit at $60 it was a gamble but this time it paid off. I had the backup case supplied with the battery but this solution works great.
    06-09-2013 07:02 PM
  1. My Samsung galaxy s3 screen drainy battery
    By migue897 in forum Samsung Galaxy S3
    Last Post: 01-11-2013, 04:13 PM
  2. Samsung Galaxy s3 smashed screen, battery bent, won't turn on
    By Daniel Wu in forum Samsung Galaxy S3
    Last Post: 01-02-2013, 09:40 AM
  3. Replies: 3
    Last Post: 11-27-2012, 08:57 AM
  4. Samsung Galaxy S3 battery issue.
    By beachprance in forum Samsung Galaxy S3
    Last Post: 10-12-2012, 09:56 AM
  5. Samsung Galaxy S3 Battery Cover - Metal
    By D2TSHR1439 in forum Marketplace Archive
    Last Post: 08-11-2012, 10:22 PM
