1. speedspeed's Avatar
    hi
    after having destroyed 2 x my 32gb memory card
    now also my charger is not working anymore, its the charger that goes into the main and then with a usb cable
    is there a fuse or anything in there?
    others have had any issues with their charger also
    its only 1 month old
    05-03-2013 03:25 PM
  2. Allanb1985's Avatar
    It seems there is an issue with the plug part as both mine and a friends have both broken. I now use my iPad plug with the original samsung cable which works perfectly and is more convenient for me. I don't know of any official Samsung acknowledgement of the issue. Hope this helps
    05-03-2013 05:12 PM
  3. meyerweb#CB's Avatar
    Pretty much any micro-USB charger rated at 800 mA or higher will work. But I recommend NOT getting one that's designed for Apple products. They will work, but will probably charge more slowly than one designed for non-Apple use.
    05-03-2013 07:18 PM
  1. S3 Car Charger?
    By cgardnervt in forum AT&T Galaxy S III Accessories
    Last Post: 08-02-2012, 07:08 AM
  2. Will this charger work for S3 battery?
    By pcguys in forum Samsung Galaxy S III Accessories
    Last Post: 07-31-2012, 12:37 PM
  3. Will this charger work for S3 battery?
    By pcguys in forum Samsung Galaxy S3
  4. Car charger for the S3?
    By kgilbertsen in forum Sprint Galaxy S III Accessories
    Last Post: 07-18-2012, 10:54 PM
  5. battery charger for galaxy s3 (same size as another phone?)
    By Funkpod in forum Samsung Galaxy S3
    Last Post: 07-09-2012, 01:35 PM
