1. Sim Sze Ying's Avatar
    I bought my s3 during a holiday in China but i am not able to charge it. The shop was just a small handphone store in Zhuhai, China and right now i have seroiously no idea how to contact them and change my phone so that i can use it. This is why i am asking help here to ask if there is any cheap repair for phones in Singapore. If you do not, please reply to me. Please help! I do not wish to spend another few hundred dollars to buy it again!
    05-09-2013 03:56 AM
  2. GTWalling's Avatar
    What happens when you plug in the charger?
    05-09-2013 11:57 AM
  3. meyerweb#CB's Avatar
    Does you have a micro USB cable? If so, what happens when you connect it to a computer USB port? Any micro-USB charger should work, so if you have, or can borrow, one try that.
    If it won't charge with any microUSB cable or charger, then I'm afraid either the phone or battery is defective.
    05-09-2013 01:35 PM
  1. Help! I have no roms installed and am unable to install any.
    By unclefarkus in forum HTC EVO 4G LTE Rooting, Rom's, and Hacks
    Last Post: 05-27-2014, 06:15 AM
  2. Replies: 28
    Last Post: 03-27-2013, 01:32 AM
  3. help my files are duplicated? dont know if its supposed to b this way!
    By poolmonitor in forum General Help and How To
    Last Post: 12-16-2012, 05:45 PM
  4. auto correct, not sure when it's supposed to work
    By complexx in forum Verizon Galaxy Nexus
    Last Post: 12-20-2011, 11:13 AM
