Galaxy Note 10 Deal: BOGO at Verizon!
  1. sonianetworks's Avatar
    I replaced my old Samsung Galaxy S3 for a new one because the battery life on the old one was horrible.
    Now that I got the replacement, I am still facing the same issues.
    The first two days, it was fine, life battery lasted all day.
    And now it's drained and I am not sure what can be the cause of this.
    05-09-2013 12:59 PM
  2. junglejunkie's Avatar
    What is "horrible?" Battery life is VERY subjective. It depends on many factors:
    1. Signal strength
    2. Network type (4G & LTE are ROUGH on battery life)
    2. Amount of widgets
    3. Number of accounts and how often they sync
    4. Screen brightness
    5. Usage (duh)
    There is probably some that I left out, but that should get you off to a start.
    Look at your battery stats. How many hours of screen on time are you getting? How many minutes of calls?
    There are some battery life threads around you can compare your stats with.
    05-09-2013 01:07 PM
  3. meyerweb#CB's Avatar
    Yeah, it's pretty hard to comment or offer suggestions when we have no data.
    At a minimum, do some screen captures and post them here so we can have something to go on. Start with the battery stats screen (Settings / Battery). Then tap on the graph at the top of that screen, and do a capture of the page that appears. Go back to the battery stats page, tap the Display row, and capture that screen, too.
    When you post them here, we can start trying to diagnose.
    05-09-2013 01:13 PM
  4. GSDer's Avatar
    In case you're better with pictures, here's what we're looking for:Spring Galaxy S3 Battery Life-uploadfromtaptalk1368155950335.jpgSpring Galaxy S3 Battery Life-uploadfromtaptalk1368155968763.jpgSpring Galaxy S3 Battery Life-uploadfromtaptalk1368155979891.jpgSent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    nolittdroid likes this.
    05-09-2013 10:19 PM
  5. blizzock's Avatar
    What should be the average battery life on the galaxy s3? I'm getting about 5 hours with minimum apps running. Talk time varies.
    05-24-2013 09:57 AM
  6. meyerweb#CB's Avatar
    There are so man things that can affect battery life it's really hard to make any predictions about what you should expect. Even so, 5 hours seems very short. Take a look at this thread as a starting point: http://forums.androidcentral.com/sam...ips-myths.html . It'll give you some things to check.
    Charge your phone to 100%, use it normally until the battery gets down around 50%, and then do the screen captures GSDer shows above, and post those here. Without data, we really can't offer any specific suggestions.
    05-24-2013 09:28 PM
  7. Tonedown03's Avatar
    I purchased a battery from eBay $10, now my battery will last all day 《95%》
    2750mAH compared to Samsung's 2100mAh.
    06-04-2013 06:42 AM
  8. Soundtrack to Chaos's Avatar
    I'm using a 7000mah
    Sent from my Sprint Samsung Galaxy s3 with a 7000mah extended battery... Because I'm not a chick with dainty hands or an HTC one user
    06-04-2013 07:35 AM
  9. chasj77's Avatar
    What a garbage phone! I had an Gal SII and it was perfect. . . .but no Jelly-Bean. On my busiest day, it rarely dipped below 50%.
    Today, like others, it is below 50% WITHOUT using it except to check mail, AND it was at 100%!
    My SII would be in the high 90 % range!!!
    I have contacted Samsung and a manager (woman, errrr) said to almost turn all the features off. Why do I need a smartphone!
    I asked is the S4 a solution . . . she said no.
    Can anyone help me before I really rattle AT&T's cage?
    Many thanks - Charles in Dallas
    06-21-2013 10:00 AM
  10. TgeekB's Avatar
    Maybe a setting, like something is syncing too often. I have both an SGS2 and SGS3 and both have similar (very good) battery life.
    chasj77 likes this.
    06-21-2013 01:34 PM
  11. KCandroidite's Avatar
    Might as well go ahead and get an iPhone....LMAO!! Sorry, I had to!
    chasj77 likes this.
    06-21-2013 01:43 PM
  12. Soundtrack to Chaos's Avatar
    You bought a phone with a removable back cover..
    Figure out the next step from there
    Sent from my Sprint Samsung Galaxy s3 running Liquid Smooth v2.7 with a 7000mah extended battery... Because I'm not a chick, a guy with dainty hands or an HTC one user
    chasj77 likes this.
    06-21-2013 07:39 PM
  13. chasj77's Avatar
    AT&T said Imust have a defective battery and are sending me a new (free!) one. Thank y'all who responded - chas
    06-23-2013 09:37 AM
  14. GSDer's Avatar
    chasj77,
    I seriously doubt that a new battery is going to solve your problems. You could follow the guidance from post #3 and provide us with some real data to go on to try to help you, or you could take Chaos's suggestion and replace the stock battery with that 7000 maH behemoth and just forget about battery woes.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
    06-23-2013 10:25 AM
  15. Soundtrack to Chaos's Avatar
    chasj77,
    Exactly, i just don't understand why people ask about how to save battery and stuff like that, just get a bigger battery and use your phone as much as you like without having to worry about charging it
    06-24-2013 10:49 PM
  16. Soundtrack to Chaos's Avatar
    This is what a real battery is capable of. Lasts all day and then some. Mostly 4g,a few hours of 3g,few minutes of wifi, few minutes of 0 signal while traveling in a dead zone, etc.
    36 hours + of usage. Have all my notifications, emails synced up, got nearly 6 hours screen on time on this run. Usually get around 7-8,but having no signal, and going into a 3g only area will do that to you
    And this all depends on how you use your phone. I know people who get 2+ - 3 days of usage while getting 10 hours on screen time. All depends on what you have your phone do. The point is, I'm charging my phone for the first time in a day and a half
    All for the low price of 39$ with a 180 day warrantee
    Attached Thumbnails Spring Galaxy S3 Battery Life-1372138149039.jpg   Spring Galaxy S3 Battery Life-1372138157375.jpg
    06-25-2013 12:33 AM
  17. Kasey Bigbee's Avatar
    I don't see why everyone is having such issues with the GS3 battery life
    my first one would get about 10-15 hours on average and I just got my replacement as my first one had dead spots all over the screen and I took it off the charger yesterday around this time and i'm using the stock Samsung battery that comes from the phone!
    to be exact i'm at 37% at this very moment and the phone has been running for 23 hours and 35 minutes and that's with HEAVY usage..
    I have my facebook, and all other social media accounts set to sync about 6 hours of that was just dedicated to games from me or family
    and my gmail is always syncing especially when I am using Chrome.....
    I don't if I got lucky but i'm just trying to figure out why this one Is lasting this long.... hahaha
    08-24-2013 11:14 AM
  18. Dylan Mark's Avatar
    Quick question. I just got an S3 from Virgin Mobile. I've noticed the battery life isn't quite as I would have expected compared to most of the reviews I've read. The life isn't horrible, it gets me through a day as you will see from my screenshots. But I was wondering if this seems a bit low to anyone else? I've been running in power saving during idle, while when I'm using it I'm not. I also use auto-brightness. I will admit I'm on 3g, not 4 since I live in a fairly rural area. Could that be a big part of the difference? Attachment 78019 Attachment 78020
    08-25-2013 11:13 PM
  19. Golfdriver97's Avatar
    Invalid file links.
    Type can have an effect, but strength is a bigger factor. I was always under the impression that auto brightness chewed up more battery power. Reason: the sensor constantly activates, and then adjusts to ambient light. So that is two functions that are constantly changing, say for sake of discussion, every 20 seconds. That is CPU and some GPU processing in the mix as well. Try a couple days with it off. See if that helps.
    From a SlimROM S3
    08-25-2013 11:41 PM
  20. meyerweb#CB's Avatar
    3g is generally easier on battery than 4g. I don't think auto brightness, in and of itself, uses more battery. The power drain for the sensor I believe is pretty trivial. But in many situations I find that I can comfortably use the screen on a dimmer setting than auto selects, which will save some power. Golfdriver is right that signal strength is the biggest issue, along with screen on time, unless there's a problem with the device.
    See this thread for more info: http://forums.androidcentral.com/sam...ips-myths.html
    Golfdriver97 likes this.
    08-26-2013 10:00 PM
  1. How can i make my samsung galaxy S3 battery life last longer?
    By JohnAce2 in forum Samsung Galaxy S3
    Last Post: 12-14-2014, 11:17 AM
  2. Galaxy s3 battery life, Good or Bad?
    By BFJ_SgsIII in forum Samsung Galaxy S3
    Last Post: 08-06-2013, 11:52 AM
  3. Galaxy S3 Battery life
    By Hellfire7 in forum Samsung Galaxy S3
    Last Post: 04-08-2013, 08:12 AM
  4. galaxy s3 battery life !!!
    By mahmoud992 in forum Samsung Galaxy S3
    Last Post: 02-26-2013, 12:24 PM
  5. Galaxy Tab Battery Life - Pretty Darn Good
    By zmetl in forum Samsung Galaxy Tab
    Last Post: 11-07-2010, 04:36 PM
