1. Shmulik Fromovitch's Avatar
    Newbie to the forum.
    I have this problem:
    everytime i restart my device, for couple of minutes, it seems like the home button is pressed randomly,
    for example, i open the play store, update my apps, and suddenly it goes back to my home screen,
    after pressing the play store again, it goes back to where it was.
    it happens not only with play store,
    it happens with every application,
    for several minutes
    (playing a game, goes to home screen, get back to game, and so on...)
    perhaps it's an application running in the background?
    any help would be appritiated,
    thanks
    05-10-2013 10:32 AM
  2. meyerweb#CB's Avatar
    That is an odd one. Since it only happens for a few minutes after a reboot, it doesn't sound like a hardware issue. Maybe stop rebooting?
    Seriously, though, did this start only recently? If so, have you added any new programs to your phone about the time this started?
    05-10-2013 10:42 AM
  3. Shmulik Fromovitch's Avatar
    i think it's about two month or so that i have this problem,
    i thought that my last (yesterday) system update (stock/rooted) would fix it, but it didn't (problem is non root related one).
    i just don't know which app causing that.
    05-10-2013 12:10 PM
  4. meyerweb#CB's Avatar
    I think what you're going to have to do is uninstall a few apps, reboot, and see if it's fixed. If not, uninstall a few more, and repeat. When it's fixed, you'll know it was one of those last few apps you took off.
    05-10-2013 12:25 PM
  5. Shmulik Fromovitch's Avatar
    I hoped for a better solution :-)
    05-10-2013 12:49 PM
  6. meyerweb#CB's Avatar
    Well, I would look in Application Manager, at the running apps tab, and start with those, since it likely to be something that's actually running in the background.
    05-10-2013 01:02 PM
  7. GSDer's Avatar
    Did you perform a Factory Reset after the OTA to 4.1.2? If not, I'd suggest that as the first course of action (being sure that you sync all of your data; backup any Call Logs, SMS/MMS, game progress, etc first).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    05-11-2013 01:17 AM
  1. Sprint Samsung Galaxy S2(epic 4G touch) Jellybean 4.2 Battery problems
    By jwaugh42069 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-29-2013, 07:35 PM
  2. Replies: 1
    Last Post: 07-07-2013, 05:30 AM
  3. Samsung Galaxy Tab (App's installation problem)...
    By kittu krrish in forum Rumored Devices Lounge
    Last Post: 10-11-2012, 10:02 AM
  4. Samsung confirms Jellybean (android 4.1) in October
    By goin_nil in forum Samsung Galaxy S3
    Last Post: 09-11-2012, 04:42 PM
  5. samsung galaxy 10.1 USB debug problem
    By wietze#AC in forum Android Sideload Wonder Machine
    Last Post: 08-21-2011, 03:26 AM
