1. dmarcus48's Avatar
    Is there anyway to stop the phone from minimizing and going into the notification screen? I find this very annoying. When using the phone I'd like it to stay in the phone app.
    05-12-2013 09:43 PM
  2. GSDer's Avatar
    Does it do this when you're using the speakerphone or just when you have the phone held next to your head?
    If the latter, does the screen stay on while you're talking/listening (you may want someone else to check) or does it go off/black (which is what it should be doing, until you move it away from your head)? If the former, then it sounds like something is interfering with the proximity sensor, and then you brush against the screen and the phone app gets minimized. You may want to check your screen protector or case to be sure they're not intruding on the proximity sensor.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    05-12-2013 10:00 PM
  3. meyerweb#CB's Avatar
    What do you mean by the notification screen? Can you post a screen capture?
    05-12-2013 10:27 PM
  4. dmarcus48's Avatar
    With the phone next to my head. I have the proximity sensor off, when I move it away from my head it stays black, until I push the menu button, then the screen comes up and the call is minimized in the notification screen.
    - - - Updated - - -
    I will try to get a screen capture and post it.
    05-13-2013 10:43 AM
  5. dmarcus48's Avatar
    Turning off the proximity settings seems to have helped this. The screen still backs out, and the phone still goes to the notification area but pushing the menu key brings it back. Thanks to all for their replies.
    05-13-2013 07:55 PM
  1. Phone going into Car Mode when plugged in to charger.
    By SET001 in forum Samsung Galaxy S3
    Last Post: 09-07-2014, 05:32 AM
  2. Phone does not go into USB mode when connecting to Win 7
    By ansextra in forum Samsung Galaxy S3
    Last Post: 12-25-2012, 01:51 PM
  3. Phone going into speaker phone mode
    By skinneejay in forum Sprint Nexus S 4G
    Last Post: 09-19-2011, 02:11 AM
  4. Turn Notifications off when in Alarm Mode
    By regiyoung151 in forum Motorola Droid X
    Last Post: 08-30-2011, 02:47 AM
  5. What makes the phone go into dock mode?
    By racermech in forum Motorola Droid
    Last Post: 12-11-2009, 07:30 PM
